Are you starting a new troubleshooting session with this task?
Display problematic components with Oracle ILOM.
-> show /System/Open_Problems
Are there any problematic components?
Display the subsystems' health with Oracle ILOM.
-> show /System -t health
Are there any unhealthy subsystems?
Are any individual components unhealthy?
Are you sure that Oracle ILOM legacy targets are enabled?
Enable Oracle ILOM legacy targets.
-> set /SP/cli legacy_targets=enabled
Investigate the sensors of suspect components.
See Display Status for Specific Components, then return to this step. Use
these tables for legacy targets.
Alarm state and FRUID
Power consumption
Voltage
Temperature
Fan speed
LED state
Were any displayed values outside the range of normal operation or
indicative of an alarm or fault?
Use the component Oracle ILOM path or component name to determine which
component to service.
See Oracle ILOM Legacy Target Replaceable Components and Faulted Item Replaceable Components for links to component service
tasks.
