1
Locate LED (top, white)
Indicates these conditions:
Fast blink –
Switch is identifying itself. To turn on a Locate LED,
at the Oracle ILOM CLI type:
set /SYS/LOCATE
value=Fast_Blink
Off – Switch
is not identifying itself. To turn off a Locate LED, at
set /SYS/LOCATE
value=Off
2
Service Action Required LED (middle, amber)
On – Service
is required. Oracle ILOM can detect a fault or failure
resulting in this indication.
The Oracle ILOM
/System/Open_Problems target
provides details about any faults that cause this
indicator to light.
Under some fault conditions, individual component
fault LEDs are turned on in addition to the Service
Required LED.
Off – Switch
is running in its normal state. There are no
faults.
3
System OK LED (middle, green)
On – Switch
is powered on and is running in its normal operating
state. No service actions are required.
Off – Switch
is not running in its normal state. Switch power might
be off. The SP might be booting.
4
SP LED (bottom, green)
On – SP is
powered on and is running in its normal operating state.
Slow blink –
The SP is booting.
Off – SP is
not running in its normal state. Power is off or the SP
has faulted.
