Perform Diagnostics at the Switch
Note -
This procedure assumes that the air duct assembly has been removed and the
SER MGT cable remains attached. See
Remove the Air Duct Assembly for
instructions.
Are you starting a new troubleshooting session with this task?
Are any power supply LEDs on?
Check the power cords and supplied power, and correct as necessary.
Refer to the Oracle InfiniBand Switch IS2-46 Installation
Guide, then return to Step 2.
Is a power supply amber Attention LED on?
Release the tab and unseat the faulted power supply, wait a minute, then
reseat the power supply and secure the tab.
Does the power supply Attention LED persist?
Is the green SP LED off?
Is a 1GBASE-T port or SFP+ port used for the network management
interface?
Is the port's Link LED on?
Does the Link LED flash on occasion?
Are you sure you know that the cabling is wired correctly with good cables
and firm connections?
Inspect and replace cabling as necessary.
Then return to Step 9.
Are you sure you know that the communication hardware (terminals, routers,
and switches) are fully functional?
Inspect and replace communication hardware as necessary.
Use new cabling and connect to a different 1GBASE-T port or SFP+ port.
Go to Step 9. If you arrive back at this step a second time, go
to Step 16.
Remove the faulted component and install a new component.
See Faulted Item Replaceable Components for links to service tasks.
Perform further diagnostics.
See Perform Additional Diagnostics at the Switch.
