Removing a single data cable is a hot-swap operation. If you are removing all data cables as part of a switch replacement, the switch must be powered off.
This task describes how to remove the cables from the switch, so that the cable can be replaced. If you are removing all cables for switch replacement, start removing the cables from the left side of the switch, working your way to the right.
If you are removing all cables for switch replacement, start with the PrizmMT cables.
The housing is either magenta or black colored.
The cable connector comes free.
The LC connector and fiber optic cable come free of the transceiver.
The transceiver comes free.
See Install a Data Cable.
See Remove the Switch.
