oracle home
Oracle
InfiniBand Switch IS2-46 Service Manual
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Oracle InfiniBand Switch IS2-46 Documentation ...
Oracle
InfiniBand Switch ...
Identifying Components
Switch Components
Updated: September 2016
Oracle
Document Information
Using This Documentation
Product Documentation Library
Feedback
Switch Components
Front Panel Components
Rear Panel Components
Detecting and Managing Faults
Troubleshooting the Switch
Begin the Diagnostic Process
Perform Diagnostics at the Switch
Perform Additional Diagnostics at the Switch
Perform Diagnostics Remotely
Perform Oracle ILOM Target Diagnostics
Identifying Components of Faulted Targets
Oracle ILOM /HOST and /SP Target Replaceable Components
Oracle ILOM /System Target Replaceable Components
Oracle ILOM Legacy Target Replaceable Components
Faulted Item Replaceable Components
Diagnostic Tools
Troubleshooting (LEDs)
Inspect the LEDs
Front Panel LEDs
SFP+ Link LEDs
RJ-45 Link LEDs
Chassis Status LEDs
Component LEDs
Accessing the SP
Access the SP (RJ-45 Port)
Access the SP (SER MGT Port)
Access the SCP (RJ-45 Port)
Configure and Enable Network Management (SER MGT Port)
Troubleshooting (Oracle ILOM /SP Targets)
Display Oracle ILOM Log Entries
Oracle ILOM Log Entry Filters
Display Network Management Configuration Properties
Display User Session Information
Display the SP Firmware Version
Troubleshooting (Oracle ILOM /System Targets)
Display Problematic Components
Open Problem Faults
Display the General Health of Components and Systems
Oracle ILOM Target Health States
Display Active Power Consumption
Troubleshooting (Oracle ILOM Legacy Targets)
Enable Oracle ILOM Legacy Targets
Display Status for Specific Components
Clear a Fault Manually
Oracle ILOM Legacy Targets for Fault State and FRUID
Oracle ILOM Legacy Targets for Alarm State
Oracle ILOM Legacy Targets for Power Consumption
Oracle ILOM Legacy Targets for Voltage
Oracle ILOM Legacy Targets for Temperature
Oracle ILOM Legacy Targets for Fan Speeds
Oracle ILOM Legacy Targets for LED States
Resettable Targets
Preparing for Service
Safety Information
Safety Symbols
ESD Measures
Antistatic Wrist Strap Use
Antistatic Mat
Service Tools
Read the Switch Serial Number (Oracle ILOM)
Locate the Switch
Prevent ESD Damage
Remove the Air Duct Assembly
Remove a Snap Bracket
Prepare to Power Off the Switch
Power Off a Power Supply
Servicing Data Cables
Identifying Data Cable Types
PrizmMT Cables
SFP+ Cable Transceivers
RJ-45 Cables
Locate a Faulty Data Cable
Remove a Data Cable
(Optional) Assemble the Optical Fiber SFP+ Cables
Install a Data Cable
Verify a Data Cable
(Optional) Clean the PrizmMT Receptacle or Connector Ferrule
Servicing the Battery
Determine if the Battery Is Faulty
Remove the Battery
Install the Battery
Verify the Battery
Servicing Fan Modules
Fan Module LED
Locate a Faulty Fan Module
Remove a Fan Module
Install a Fan Module
Verify a Fan Module
Servicing Power Supplies
Power Supply LEDs
Locate a Faulty Power Supply
Remove a Power Supply
Install a Power Supply
Verify a Power Supply
Replacing the Switch
Switch LEDs
Determine if the Switch Is Faulty
Remove the Switch
Install the Switch
Verify the Switch
Returning the Switch to Operation
Retrieve the Power Cords and SER MGT Cable
Power On a Power Supply
Connect the SER MGT Cable
Configure the Replacement Switch
Install a Snap Bracket
Install the Air Duct Assembly
Glossary
Index
Index Numbers and Symbols
Index A
Index B
Index C
Index D
Index E
Index F
Index H
Index I
Index L
Index N
Index O
Index P
Index R
Index S
Index T
Index U
Index V
Language:
English
Switch Components
No.
Description
Links
1
Fan module
2
SER MGT module (SMM) (battery inside)
3
Power supply
Related Information
Previous
Next
