Installing a single data cable is a hot-swap operation. If you are installing all data cables at one time, the switch should be in a powered off state.
See Remove a Data Cable.
See the Oracle InfiniBand Switch IS2-46 Installation Guide, routing data cables.
If you are installing all cables as part of a switch replacement, start with the RJ-45 cables.
The tab on the connector is up for the upper row of receptacles and down for the lower row of receptacles.
The product label on the connector is up for the upper row of receptacles and down for the lower row of receptacles.
The receptacle should be clean and free of dirt or debris. If the receptacle is dirty, clean it. See (Optional) Clean the PrizmMT Receptacle or Connector Ferrule.
The connector should be clean and free of dirt or debris. If the connector is dirty, clean it. See (Optional) Clean the PrizmMT Receptacle or Connector Ferrule.
See Verify a Data Cable.
