Power On a Power Supply
Note -
Powering on either power supply powers on the switch.
Reconnect the power cord to the power supply.
The AC LED lights green to indicate that the power supply is connected to
facility power. A moment later, the OK LED lights green to indicate the power
supply is at full power.
If you replaced a power supply as part of a service operation, verify that the
power supply Attention LED is not on.
Consider your next step.
Connect the SER MGT cable so that you can configure the replacement
switch.
See Connect the SER MGT Cable.
