Prepare to Power Off the Switch
Perform this task before powering off the switch for a switch replacement.
Note -
The steps of this task are a generalization of what is to be done. For more
thorough instructions on how to accomplish these steps, refer to the
Oracle EDR InfiniBand Switch and Virtualized I/O Systems
Administration Guide, the Oracle Fabric Manager 5.0
Administration Guide, and the Oracle Fabric OS 1.0
Administration Guide.
Notify affected users that the switch is to be shut down.
Access the SCP on the switch to be removed.
See Access the SCP (RJ-45 Port).
If the switch to be removed is configured with the master Subnet Manager,
initiate a handover to the standby Subnet Manager.
Refer to the Oracle Fabric Manager 5.0 Administration
Guide. Wait for any handover to complete.
If the switch to be removed is configured with any Subnet Manager, set the
priority to the lowest.
Guide.
Create a backup of the switch configuration for the switch to be
removed.
On the switch, create a backup of the Oracle Fabric Manager
configuration.
Guide.
On the switch, create a backup of the Oracle Fabric OS
configuration.
Refer to the Oracle Fabric OS 1.0 Administration
Guide.
Access the SP.
See Access the SP (RJ-45 Port)
Write the SEFOS configuration to Oracle ILOM, and create a backup of
the Oracle ILOM configuration.
This backs up the SEFOS configuration. Refer to the Oracle
EDR InfiniBand Switch and Virtualized I/O Systems Administration
Guide.
Transfer the backup files to a safe place.
Power off the switch.
See Power Off a Power Supply.
