Remove the power cord in a slow wiggling motion.
![]() | Caution - Pulling or jerking the cord out from the power supply might cause your hand to catch on the snap brackets, if they are installed. |
The power supply is completely powered off.
See Remove a Data Cable.
See Install a Data Cable.
