Oracle® InfiniBand Switch IS2-46 Service Manual
Exit Print View
Updated: September 2016
Verify a Data Cable
After you install a data cable, you can verify its functionality.
  1. Verify that the data cable is no longer considered faulty.
    See Locate a Faulty Data Cable, then return to this task.
  2. If the known good replacement data cable is still identified as faulty, check the cable's connection remote from the switch.
    See Detecting and Managing Faults for assistance.
Related Information
