Oracle ILOM Legacy Targets for Voltage
This table lists voltage sensors. An out-of-range value might indicate a faulted
component. See Oracle ILOM Legacy Target Replaceable Components or Faulted Item Replaceable Components for a
link to the service task for that component.
Line voltage into PS 0
/SYS/PS0/V_IN
100 to 252 volts
Power source or power cord
Line voltage into PS 1
/SYS/PS1/V_IN
100 to 252 volts
Main board 1.0 VDC
/SYS/MB/V_+1V0
0.931 to 1.058 volts
Switch
Main board 1.2 VDC
/SYS/MB/V_+1V2
1.127 to 1.274 volts
Switch
Main board 1.5 VDC
/SYS/MB/V_+1V5
1.352 to 1.646 volts
Switch
Main board 1.8 VDC
/SYS/MB/V_+1V8
1.686 to 1.911 volts
Switch
Main board 2.5 VDC
/SYS/MB/V_+2V5
2.359 to 2.652 volts
Switch
Main board 3.3 VDC
/SYS/MB/V_+3V3
3.120 to 3.490 volts
Switch
Main board HCA 0.85 VDC
/SYS/MB/V_+0V85_HCA
0.823 to 0.931 volts
Switch
Main board HCA 1.05 VDC
/SYS/MB/V_+1V05_HCA
1.000 to 1.127 volts
Switch
Main board IB switch chip 0.85 VDC
/SYS/MB/V_+0V85_IBSW
Switch
Main board IB switch chip 1.05 VDC
/SYS/MB/V_+1V05_IBSW
Switch
Main board MBOM 3.3 VDC
/SYS/MB/V_+3V3_MBOMA
Switch
Main board Standby 3.3 VDC
/SYS/MB/V_+3V3_STDBY
Switch
RTC backup battery
/SYS/MB/V_VBAT
> 2.548 volts
Battery
SP 1.0 VDC
/SYS/SP/V_+1V0
0.872 to 1.117 volts
Switch
SP 1.5 VDC
/SYS/SP/V_+1V5
Switch
SP 1.8 VDC
/SYS/SP/V_+1V8
1.578 to 2.009 volts
Switch
SP 3.3 VDC
/SYS/SP/V_+3V3
2.944 to 3.685 volts
Switch
Supplied voltage out of PS 0
/SYS/PS0/V_OUT
10 to 14 volts
Power supply 0
Supplied voltage out of PS 1
/SYS/PS1/V_OUT
10 to 14 volts
Power supply 1
