Oracle® InfiniBand Switch IS2-46 Service Manual
Exit Print View
Updated: September 2016
Glossary
1
10GBASE-T – LR
Ethernet technology that supports cable distances of over 300 meters.
10GBASE-T – SR
Standard 10GbE Ethernet technology.
10GbE/40GbE module
I/O module for the Oracle Fabric Interconnect F2-12 that supports 10GbE and 40GbE interfaces.
16G Fibre Channel module
I/O module for the Oracle Fabric Interconnect F2-12 that supports Fibre Channel interfaces.
A
AD
Abbreviation for Active Directory.
adapter
Physical device, such as an HCA or NIC, that enables a host to communicate through a fabric or network.
ASR
Automatic Service Request. A feature of Oracle hardware that automatically opens service requests when specific hardware faults occur. ASR is integrated with My Oracle Support (MOS) and requires a support agreement. See also MOS.
C
CFM
Cubic feet per minute. A standard of measuring airflow.
CMB
Abbreviation for cable management bracket. A component that supports and groups cables extending from the chassis.
D
DN
Abbreviation for distinguished name. An Active Directory term.
DSA key
Digital Signature Algorithm key. A component of SSH authentication. See also RSA and SSH.
E
EDR
Extended Data Rate. A throughput of InfiniBand (IB) technology, typically 100Gbps. See also IB.
EMS module
Embedded Management Switch module. A component within the switch chassis that provides an Ethernet switch and management controller, using the SEFOS operating system. See also SEFOS.
Ethernet gateway
A device that either enables data transference from one protocol to another, for example IB to Ethernet. Or a device that serves as a routing node for an Ethernet network.
Ethernet management switch
An Ethernet switch that enables single point management of multiple service processors (SP) or hosts through their respective network management interfaces. See also SP.
F
fabric card
A component of an IB switch chassis that provides a spine topology construct. See also IB SFM module.
fabric interconnect
Short name for an IB switch that provides gateway services and additional functionality.
fan module
A hot-swappable replaceable component that provides cooling air to the chassis interior.
Fibre Channel
A data transference technology used primarily for storage systems.
FM
Abbreviation of fan module. See also fan module.
G
GB
Abbreviation of GigaByte. 1 GB is approximately 1000 MB.
GbE
Abbreviation of Gigabit Ethernet. A unit of throughput for Ethernet technology.
GUID
Globally unique identifier. A 32-digit hexadecimal number that uniquely identifies an IB node. See also IB.
H
HCA
Host channel adapter. A physical device that is the terminating point of an IB node used in a computing instance, such as a server or host.
housing
The colored plastic portion of the PrizmMT connector, magenta for 4x, black for 12x. Though it functions as a release device and not as a containment, the term "housing" was assigned by the manufacturer, USConec.
I
I2C
A hardware bus employing the IPMI protocol to query and affect I2C nodes. See also IPMI and Oracle ILOM.
IB
InfiniBand. A high bandwidth messaging technology, used for very high performance computing.
IB SFM module
I/O module for the Oracle InfiniBand Switch IS2-254 that provides a spine topology construct. Is used in conjunction with the IB SLM modules. See also fabric card and IB SLM module.
IB SLM module
I/O module for the Oracle InfiniBand Switch IS2-254 that provides a leaf topology construct. Is used in conjunction with the IB SFM modules. See also line card and IB SFM module.
IB switch
A physical device that provides connections between nodes within an IB fabric.
ILOM
See Oracle ILOM.
I/O module
A user-replaceable physical interface component for the Oracle Fabric Interconnect F2-12 and Oracle InfiniBand Switch IS2-254.
IPMI
Intelligent Platform Management Interface. A protocol for monitoring and controlling chassis components over the I2C bus.
K
KVMS
Abbreviation for keyboard, video, mouse, and storage. A means of providing remote operation of a host.
L
LDAP
Lightweight Directory Access Protocol. A protocol for providing directory services over IP.
LDAP over SSL
A scheme of securing LDAP through a Secure Sockets Layer tunnel. See also LDAP.
leaf switch
A switch utilizing a leaf topology.
line card
A component of an IB switch chassis, that provides a leaf topology construct. See also IB SLM module.
long-range IB module
I/O module for the Oracle Fabric Interconnect F2-12 that supports QDR IB throughput over distances up to 40 kilometers.
LR IB IOM
LR transceiver
A transceiver used for long range Fibre Channel communication.
M
MAC
Machine Allocation Code. A 12-digit hexadecimal number that uniquely identifies a network node.
MIB
Management Information Base. A plain text file that contains a collection of object identifiers (OID). Used when managing a switch with the SNMP protocol. See also OID and SNMP.
module
A user-replaceable component for a chassis, typically externally accessible. See also I/O module and fan module.
MOS
My Oracle Support, at: http://support.oracle.com
N
network management
A means of managing an SP or SCP through an Ethernet network. See also serial management, SP, and SCP.
O
OID
Object identifier. Component of a MIB that serves a particular purpose and has parameters that are interpreted by the SNMP protocol. See also MIB and SNMP.
Oracle F2 10 Gb and 40Gb Ethernet Module
An I/O module that provides either 10GbE or 40GbE functionality.
Oracle F2 Dual Port 16G Fibre Channel Module
An I/O module that provides 16Gb Fibre Channel functionality.
Oracle F2 Long Range InfiniBand Module
An I/O module that provides QDR InfiniBand functionality over long distances.
Oracle F2 Quad Port 10GBASE-T Module
An I/O module that provides four 10GbE interface functionality.
A virtualization switch. See also virtualization switch.
Oracle Fabric Manager
A web-based GUI to administer the switch and fabric.
Oracle Fabric OS
Oracle Fabric Operating System. The operating system within the SCP, that manages the fabric. See also SCP.
Oracle ILOM
Oracle Integrated Lights-Out Manager. An interface using the IPMI protocol and the I2C bus to monitor and control the hardware components of a chassis.
Oracle InfiniBand Switch IS2-46
A leaf switch. See also leaf switch.
A spine switch. See also spine switch.
Oracle Linux OS
Oracle Linux operating system. A UNIX-based operating system, often embedded into service processors. See also SP.
Oracle Solaris OS
Oracle Solaris operating system. A UNIX-based operating system, typically used for high-performance Enterprise computing platforms.
P
PrizmMT cable
An optical fiber connector and cable used for IB 4x and 12x technology. Is configured with a PrizmMT ferrule. Appears similar to, but is not compatible with standard MT cables and connectors. See also standard MT cable.
Q
QSFP
Quad small form-factor pluggable. A form-factor for high-speed data interconnects.
R
RADIUS
Remote Authentication Dial-In User Service. A protocol that provides authentication, authorization, and accounting for users.
RJ-45
Standard for an eight-pin modular form-factor for Ethernet interconnects.
RSA key
Rivest Shamir Adleman algorithm key. A component of SSH authentication. See also DSA and SSH.
S
SCP
System control processor. A type of service processor that manages more complex and resource intensive services, such as IB technology, fabric management interfaces, the Subnet Manager, and so on. The SCP might also be the chassis host. See also SP.
SEFOS
Sun Ethernet Fabric Operating System. The operating system used by the EMS module to administer the Ethernet network. See also EMS module.
SER MGT
Serial management. A low-speed serial datastream used to interface with the SP. See also SP.
serial management
A means of managing an SP or SCP through a serial datastream. See also SER MGT, network management, SP, and SCP.
SFP+
Small form-factor pluggable. A form-factor for high-speed data interconnects.
SNMP
Simple Network Management Protocol. A machine interface for remote monitoring and controlling of a switch. Uses MIBs and OIDs to exchange messages containing data or instructions. See also MIB and OID.
SP
Service processor. A device that monitors and controls a chassis, regardless of the chassis host state, through an Oracle ILOM interface. See also Oracle ILOM and SCP.
spine switch
A switch utilizing a spine topology.
SR transceiver
A transceiver used for short range Fibre Channel communication.
SSH
Secure Shell. A secure network communication protocol, utilizing DSA and RSA algorithms. See also DSA and RSA.
standard MT cable
An optical fiber connector and cable used for IB 4x technology. Appears similar to, but is not compatible with PrizmMT cables and connectors. See also PrizmMT cable.
switch front
The intake end of the switch chassis that faces the cold aisle when mounted in a rack. Typically is the end with fan modules and power supplies.
switch rear
The exhaust end of the switch chassis that faces the hot aisle when mounted in a rack. Typically is the end populated with high-speed data connections.
V
VAC
Voltage alternating current.
VDC
Voltage direct current.
A switch supporting multiple interfaces having virtualization capabilities.
W
WWN
World Wide Name. An identifier used for Fibre Channel and other storage interface devices.
WWNN
World Wide Node Name. A Fibre Channel name specifically for a node.
WWPN
World Wide Port Name. A Fibre Channel name specifically for a port.
