Exit Print View
You need these tools for most service operations:
Antistatic wrist strap
Antistatic mat
No. 1 Phillips screwdriver
No. 2 Phillips screwdriver
Paper clip
PrizmMT ferrule cleaner - USConec part number 16899
Safety Information
Read the Switch Serial Number (Oracle ILOM)
Locate the Switch
Prevent ESD Damage
Remove the Air Duct Assembly
Remove a Snap Bracket
Prepare to Power Off the Switch
Power Off a Power Supply
