Go to main content
Oracle® Server X5-4 Service Manual
Exit Print View
Updated: December 2015
Tools and Equipment
To service the system, you need the following tools:
  • No. 2 Phillips screwdriver
  • Anti-static wrist strap
  • ESD mat and grounding strap
You might also need a system console device, such as one of the following:
  • PC or workstation with RS-232 serial port
  • ASCII terminal
  • Terminal server
  • Patch panel connected to a terminal server
