Installing a storage drive into a server is a two-step process. You must first install the storage drive into the drive slot, and then configure that drive to the server.
Before You Begin
For serviceability considerations, see Component Serviceability.
For storage drive designation information, see DVD, Storage Drive, and USB Designations.
Use one of the power options described in Power On the Server.
The procedures that you perform at this point depend on how your data is configured. You might need to partition the drive, create file systems, load data from backups, or have the drive updated from a RAID configuration.
See Also
