Diagnostic Tools
The server and its accompanying software and firmware contain
diagnostic tools and features that can help you isolate
component problems, monitor the status of a functioning
system, and exercise one or more subsystems to disclose more
subtle or intermittent hardware-related problems.
Each diagnostic tool has its own specific strength and
application. Review the tools listed in this section and
determine which tool might be best to use for your
situation. Once you have determined the tool to use, you can
access it locally (while at the server) or remotely.
The selection of diagnostic tools available for your server range in complexity from a
comprehensive validation test suite (Oracle VTS) to a chronological event log (Oracle ILOM System
Log). The selection of diagnostic tools also include standalone software packages, firmware-based
tests, and hardware-based LED indicators.
The following table summarizes the diagnostic tools that you can use when troubleshooting or
monitoring your server.
Oracle ILOM
SP firmware
Monitors environmental conditions and component functionality sensors, generates alerts,
performs fault isolation, and provides remote access.
Can function on either standby power mode or full power mode and is not OS dependent.
Designed for remote and local access.
Preboot Menu
SP firmware
Enables you to restore some Oracle ILOM default settings when Oracle ILOM is not accessible.
Can function on standby power and when operating system is not running.
Local, but remote serial access is possible if the SP serial port is connected to a
network-accessible terminal server.
Hardware-based LED indicators
Hardware and SP firmware
Indicates status of overall system and particular components.
Available when system power is available.
Local, but sensor and indicators are accessible from Oracle ILOM web interface or command-line
interface (CLI).
Power-on Self-Test (POST)
Host firmware
Tests core components of system: CPUs, memory, and motherboard I/O bridge integrated
circuits.
Runs on startup. Available when the operating system is not running.
Local, but can be accessed through Oracle ILOM Remote Console.
U-Boot
SP firmware
Initializes and tests aspects of the service processor (SP) prior to booting Oracle ILOM and
the operating system. Tests SP memory, SP, network devices and I/O devices.
UEFI Diagnostics
System BIOS
The UEFI diagnostics can test and detect problems on all CPU, memory, disk drives, and network
ports. It is used on systems that support UEFI.
You can use either the Oracle ILOM web interface or the command-line interface (CLI) to run
UEFI diagnostics.
Remote access through Oracle ILOM Remote Console.
Oracle Solaris commands
Operating system software
Displays various kinds of system information.
Requires operating system.
Local, and over network.
Oracle Linux commands
Oracle VTS
Diagnostic tool standalone software
Exercises and stresses the system, running tests in parallel.
Requires operating system. Install Oracle VTS software separately.
View and control over network.
