Use this procedure to remove a storage drive from the server.
Before You Begin
For serviceability considerations, see Component Serviceability.
For storage drive designation information, see DVD, Storage Drive, and USB Designations.
NVMe storage drives must first be prepared using operating system commands to prevent data loss and an operating system crash.
A cold-swap is required if the storage drive:
This removes the logical software links to the drive and prevents any applications from accessing it. To take a storage drive offline, use OS-specific commands or the HBA software (MegaRAID or StorCLI).
Use one of the power-off options described in Prepare the Server for Cold Service.
If you are hot-plugging a drive, ensure that the blue Ready to Remove indicator is lit.
If you are replacing the drive, continue to Install a Storage Drive (CRU).
If you are not replacing the drive, Install a Storage Drive Filler Panel (CRU) in the empty drive slot to maintain proper airflow and perform administrative tasks to configure the server to operate without the drive.
If you performed a cold-service procedure, power on the server.
