sg_read_block_limits - sends a SCSI READ BLOCK LIMITS command
sg_read_block_limits [--help] [--hex] [--raw] [--verbose] [--version] DEVICE
SG_READ_BLOCK_LIMITS(8) SG3_UTILS SG_READ_BLOCK_LIMITS(8) NAME sg_read_block_limits - sends a SCSI READ BLOCK LIMITS command SYNOPSIS sg_read_block_limits [--help] [--hex] [--raw] [--verbose] [--version] DEVICE DESCRIPTION Send a SCSI READ BLOCK LIMITS command to DEVICE and outputs the response. This command is defined for tape (drives) and its description is found in the SSC documents at http://www.t10.org . OPTIONS Arguments to long options are mandatory for short options as well. -h, --help output the usage message then exit. -H, --hex output response in hex (rather than decode it). -r, --raw output response in binary to stdout. -v, --verbose increase the level of verbosity, (i.e. debug output). -V, --version print the version string and then exit. EXIT STATUS The exit status of sg_read_block_limits is 0 when it is successful. Otherwise see the sg3_utils(8) man page. EXAMPLES It is usually okay to use no options. Here is an invocation (on the first line following the "#" command prompt) followed by some typical output: # sg_read_block_limits /dev/st0 Read Block Limits results: Minimum block size: 1 byte(s) Maximum block size: 16777215 byte(s), 16383 KB, 15 MB AUTHORS Written by Douglas Gilbert. REPORTING BUGS Report bugs to <dgilbert at interlog dot com>. COPYRIGHT Copyright (C) 2009-2011 Douglas Gilbert This software is distributed under a FreeBSD license. There is NO war- ranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PUR- POSE. ATTRIBUTES See attributes(5) for descriptions of the following attributes: +---------------+--------------------------+ |ATTRIBUTE TYPE | ATTRIBUTE VALUE | +---------------+--------------------------+ |Availability | system/storage/sg3_utils | +---------------+--------------------------+ |Stability | Uncommitted | +---------------+--------------------------+ SEE ALSO sg3_utils(sg3_utils) NOTES This software was built from source available at https://java.net/projects/solaris-userland. The original community source was downloaded from http://sg.danny.cz/sg/p/sg3_utils-1.33.tgz Further information about this software can be found on the open source community website at http://sg.danny.cz/sg/sg3_utils.html. sg3_utils-1.31 February 2011 SG_READ_BLOCK_LIMITS(8)
