Understanding the Hardware Architecture
Understanding the Firmware and Software Environment
General Installation Site Guidelines
Reviewing the Physical Specifications
Reviewing the Power Requirements
Preparing the Unloading Route and Unpacking Area
Equipment Needed for Installation
Attach an Antistatic Wrist Strap
Optional Component Installation
Connecting the Front SP Cables
Connecting the Rear Power Cords and Data Cables
Prepare the Cable Routing Brackets
Connect the EMS Network Cables
Powering On the Server for the First Time
Connect Terminals or Emulators to the SP SER MGT Ports
Switch On the Facility Circuit Breakers
Set Oracle ILOM Network Addresses
Set the Altitude of the Server
Oracle Solaris OS Configuration Parameters
Additional Software Configuration and Testing
Understanding the System Architecture
Understanding PCIe Device Root Complexes
Control Domain and Reserved Root Complexes
Fully-Populated Default Configuration
Understanding PCIe Slot Root Complex Names and Device Paths
Understanding DCU0 Root Complex Names and Device Paths
Understanding DCU1 Root Complex Names and Device Paths
Understanding DCU2 Root Complexes and Device Paths
Understanding DCU3 Root Complexes and Device Paths
PCIe Device Root Complex Failover Behavior
Understanding EMS SAS Paths to the Internal Drives
SAS Paths From EMS Module to Drives
Understanding Internal Drive Device Paths
HDD and SSD Device Path Differences
Understanding DCU0 Drive Device Paths
Fully-Populated DCU0 Drive Device Paths
Half-Populated DCU0 Hard Drive Device Paths
Understanding DCU1 Drive Device Paths
Fully-Populated DCU1 Drive Device Paths
Half-Populated DCU1 Drive Device Paths
Understanding DCU2 Drive Device Paths
Fully-Populated DCU2 Drive Device Paths
Half-Populated DCU2 Drive Device Paths
Understanding DCU3 Drive Device Paths
Fully-Populated DCU3 Drive Device Paths
Half-Populated DCU3 Drive Device Paths
Understanding Network Port Device Paths
DCU0 Network Port Device Paths
DCU1 Network Port Device Paths
DCU2 Network Port Device Paths
DCU3 Network Port Device Paths
Understanding Configuration Guidelines
Understanding System Administration Resources
Understanding Platform-Specific Oracle ILOM Features
Oracle VM Server for SPARC Overview
Multipathing Software Overview
Oracle ILOM Remote System Console Plus Overview
Oracle Hardware Management Pack Overview
Oracle Enterprise Manager Ops Center
Time Synchronization and NTP Service
Multi-Domain Extensions to ILOM MIBs
Establish a Network Management Connection to Oracle ILOM
Switch Between the Oracle ILOM CLI and the System Console on a Host
Controlling the Server, Domains, and Devices
Resetting the Server, SP, or Domains
Managing the Server's Boot Behavior
Booting and Shutting Down the OS
Configuring Oracle ILOM User Accounts and Roles
Record Network Parameter Values
Viewing the Network Configuration
Administering CMUs, CMPs, and DIMMs
Administering IOUs and PCIe Device Root Complexes
Identifying Domain-Level Commands
Obtain the Server Serial Number
Viewing Server and Component Information
XSCF and Oracle ILOM Command Comparison
Identifying SP Configuration and Administration Commands
Identifying Domain Administration Commands
Identifying Internal Components
Component Service Task Reference
Interpreting Log Files and System Messages
Removing Power From the Server
Servicing Trim Panels and the Kick Plate
Trim Panel Service Preparation
Check a Service Processor Battery
Replace a Service Processor Battery
I/O Switch Board Configuration
Servicing Cable Management Assemblies
Remove a Cable Management Assembly
Install a Cable Management Assembly
Understanding I/O Card Slot Configuration
Understanding I/O Card Slot Device Paths and FRU Paths
Sun Flash Accelerator F40 and F80 PCIe Cards
Locate an I/O Card in the Server
Prepare an I/O Card For Removal
Remove an I/O Card From the Server
Remove an I/O Card From a Carrier
Install an I/O Card in a Carrier
Install an I/O Card in the Server
Remove a Filler Panel From the Server
Remove a Filler Panel From a Carrier
Install a Filler Panel in a Carrier
Install a Filler Panel in the Server
Relocate a Sun Flash Accelerator F40 PCIe Card
Understanding EMS Configurations
Determine Hard Drive Cage and EMS Part Numbers
Servicing HDDs, SSDs, and Drive Filler Panels
Understanding HDD and SSD Slot Configurations
CMU Upgrades in a SPARC M5-32 Server
Display General CMU Information
Display the CMU Quantity and Type
Unpacking and Inspecting a CMU
Servicing the Front Filler Panel
Install the Front Filler Panel
Servicing a Cabled Lower Bus Bar Assembly
Remove a Cabled Lower Bus Bar Assembly
Install a Cabled Lower Bus Bar Assembly
Servicing the Scalability Card Cage
Remove the Scalability Card Cage
Install the Scalability Card Cage
Servicing the Scalability Fans Cable
Remove the Scalability Fans Cable
Install the Scalability Fans Cable
Servicing the Power System Cage
Prepare to Replace Crown Clips on a Bus Bar
Return the Server to Operation
Servicing an I/O Power Cable Assembly
Remove an I/O Power Cable Assembly
Install an I/O Power Cable Assembly
Servicing the Scalability Assembly
Remove the Scalability Assembly
Install the Scalability Assembly
Servicing the Power System Cage to Scalability Assembly Cable
Remove the Power System Cage to Scalability Assembly Cable
Install the Power System Cage to Scalability Assembly Cable
Servicing the PSDB to Scalability Midplane Cable
Remove the PSDB to Scalability Midplane Cable
Install the PSDB to Scalability Midplane Cable
Servicing the Internal Link to Front LED Panel Cable
Remove the Internal Link Cable for the Front LED Panel
Install the Internal Link Cable for the Front LED Panel
Servicing the Rear LED Panel Cable
Remove the Rear LED Panel Cable
Install the Rear LED Panel Cable
Servicing Midplane Power Cables
Prepare to Remove a Midplane Power Cable
Install a Midplane Power Cable
Servicing the I/O Data Cable Assembly
Remove an I/O Data Cable Assembly
Install an I/O Data Cable Assembly
Prepare to Remove the Midplane
Prepare the Old Midplane for Return
Supported CMU configurations within a single DCU are as follows:
All four CMUs are installed: rKVMS is supported with redundant paths, all PCIe and EMS slots are accessible, and CMUs are redundant.
Only the first and second CMUs installed: rKVMS is supported and Bounded PDomains have redundant rKVMS paths. If any CMP fails in a Bounded PDomain, the rKVMS connection remains. PCIe slots 9–16 and EMS slots 3–4 are inaccessible. There is no CMU redundancy, so if either CMU fails, the DCU cannot access the SSBs.
Only the first and fourth CMUs installed: rKVMS is supported with no redundancy. If the CMU in the first slot fails, the rKVMS connection is lost. All PCIe and EMS slots are accessible, but if one CMU fails, half of the slots will be disabled. There is no CMU redundancy, so if either CMU fails, the DCU cannot access the SSBs.
Only the second and third CMUs installed: rKVMS is supported with no redundancy. If the CMU in the second slot fails, the rKVMS connection is lost. All PCIe and EMS slots are accessible, but if one CMU fails, half of the slots will be disabled. There is no CMU redundancy, so if either CMU fails, the DCU cannot access the SSBs.
Only the third and fourth CMUs installed: rKVMS is not supported. PCIe slots 1–8 and EMS slots 1–2 are inaccessible. There is no CMU redundancy, so if either CMU fails, the DCU cannot access the SSBs.
Three CMUs installed in any order: rKVMS is supported and all PCIe and EMS slots are accessible. Only one CMU pair and half of the PCIe and EMS slots are redundant. rKVMS is redundant when CMUs are installed in the first and second slots.
Configurations with only the first and third CMUs installed or only the second and fourth CMUs installed are not supported.
A single DCU in a non-Bounded PDomain must have at least two functioning CMUs (one even numbered and one odd numbered) to access the SSBs.
In configurations where a DCU has only two CMUs, individual CMPs can be unconfigured. In configurations where a DCU has three or four CMUs, an entire CMU will be unconfigured if a CMP needs to be reconfigured.
A Bounded PDomain can have only one DCU assigned to it and can have a minimum of one CMP.
When a CMP or CMU fails, or when a CMU is removed, the primary root complexes on that CMP or CMU will no longer be available. For guidelines about setting the Oracle ILOM ioreconfigure property on the PDomain host, see PCIe Device Root Complex Failover Behavior.
Do not assign root complexes pci_1, pci_17, pci_33, and pci_49 to non-primary domains. The four root complexes must always be available to the control domain. See FMA Fault Proxying and Reserved Root Complexes for details.
Do not assign an empty DCU to a PDomain. If the system selects the SPP for the empty DCU to be the PDomain-SPP, the DCU to SP interconnect will fail. See FMA Fault Proxying and Reserved Root Complexes for details.
Do not mix SPARC M5 CMUs and SPARC M6 CMUs within the same DCU. A DCU must only contain the same CMU version.
