base64
(1)
Name
base64 - base64 encode/decode data and print to standard
output
Synopsis
base64 [OPTION]... [FILE]
Description
User Commands BASE64(1)
NAME
output
SYNOPSIS
DESCRIPTION
Base64 encode or decode FILE, or standard input, to standard
output.
-d, --decode
decode data
-i, --ignore-garbage
when decoding, ignore non-alphabet characters
-w, --wrap=COLS
wrap encoded lines after COLS character (default 76).
Use 0 to disable line wrapping
--help
display this help and exit
--version
output version information and exit
With no FILE, or when FILE is -, read standard input.
The data are encoded as described for the base64 alphabet in
RFC 3548. When decoding, the input may contain newlines in
addition to the bytes of the formal base64 alphabet. Use
--ignore-garbage to attempt to recover from any other
non-alphabet bytes in the encoded stream.
AUTHOR
Written by Simon Josefsson.
REPORTING BUGS
Report base64 bugs to bug-coreutils@gnu.org
GNU coreutils home page: <http://www.gnu.org/software/core-
utils/>
General help using GNU software: <http://www.gnu.org/geth-
elp/>
Report base64 translation bugs to <http://translationpro-
ject.org/team/>
COPYRIGHT
Copyright (C) 2012 Free Software Foundation, Inc. License
GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and
GNU coreutils 8.16 Last change: March 2012 1
redistribute it. There is NO WARRANTY, to the extent per-
mitted by law.
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | file/gnu-coreutils |
|Stability | Uncommitted |
SEE ALSO
The full documentation for base64 is maintained as a Texinfo
manual. If the info and base64 programs are properly
installed at your site, the command
info coreutils 'base64 invocation'
should give you access to the complete manual.
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from
http://ftp.gnu.org/gnu/coreutils/coreutils-8.16.tar.xz
Further information about this software can be found on the
open source community website at http://www.gnu.org/soft-
ware/coreutils/.
GNU coreutils 8.16 Last change: March 2012 2
