swift-container-replicator
(1)
Name
swift-container-replicator - OpenStack  Swift  container
replicator
Synopsis
/usr/lib/swift/swift-container-replicator           [CONFIG]
[-h|--help] [-v|--verbose] [-o|--once]
Description
OpenStack Swift                     swift-container-replicator(1)
NAME
     replicator
SYNOPSIS
DESCRIPTION
     Replication  is  designed to keep the system in a consistent
     state in the face of temporary error conditions like network
     outages or drive failures. The replication processes compare
     local data with each remote copy to ensure they all  contain
     the latest version. Container replication uses a combination
     of hashes and shared high water  marks  to  quickly  compare
     subsections of each partition.
     Replication  updates  are  push based. Container replication
     push missing records  over  HTTP  or  rsync  whole  database
     files. The replicator also ensures that data is removed from
     the system. When an container item is deleted a tombstone is
     set  as  the latest version of the item. The replicator will
     see the tombstone and ensure that the item is  removed  from
     the entire system.
     The options are as follows:
         -v
         --verbose
             log to console
         -o
         --once
             only run one pass of daemon
     The  container  replicator  should  be  enabled and disabled
     using the Solaris Service Management Facility, smf(5).   The
     service FMRI for the container replicator is:
       svc:/application/openstack/swift/swift-container-replicator
DOCUMENTATION
     More  in  depth documentation in regards to swift-container-
     replicator and also about OpenStack Swift as a whole can  be
     found at http://swift.openstack.org/index.html
OpenStack             Last change: 8/26/2011                    1
ATTRIBUTES
     See   attributes(5)   for   descriptions  of  the  following
     attributes:
     |ATTRIBUTE TYPE |   ATTRIBUTE VALUE     |
     |Availability   | cloud/openstack/swift |
     |Stability      | Uncommitted           |
SEE ALSO
     container-server.conf(4), smf(5)
NOTES
     This  software  was   built   from   source   available   at
     https://java.net/projects/solaris-userland.    The  original
     community  source  was   downloaded   from    http://launch-
     pad.net/swift/havana/1.10.0/+download/swift-1.10.0.tar.gz
     Further  information about this software can be found on the
     open source community website at  http://www.openstack.org/.
OpenStack             Last change: 8/26/2011                    2
