sql
(1)
Name
sql - execute a command on a database determined by a dburl
Synopsis
sql [options] dburl [commands]
sql [options] dburl < commandfile
#!/usr/bin/sql --shebang [options] dburl
Description
parallel SQL(1)
NAME
SYNOPSIS
DESCRIPTION
GNU sql aims to give a simple, unified interface for
accessing databases through all the different databases'
command line clients. So far the focus has been on giving a
common way to specify login information (protocol, username,
password, hostname, and port number), size (database and
table size), and running queries.
The database is addressed using a DBURL. If commands are
left out you will get that database's interactive shell.
GNU sql is often used in combination with GNU parallel.
dburl A DBURL has the following syntax: [sql:]vendor://
[[user][:password]@][host][:port]/[database][?sqlquery]
See the section DBURL below.
commands The SQL commands to run. Each argument will have a
newline appended.
Example: "SELECT * FROM foo;" "SELECT * FROM bar;"
If the arguments contain '\n' or '\x0a' this will
be replaced with a newline:
Example: "SELECT * FROM foo;\n SELECT * FROM bar;"
If no commands are given SQL is read from the
keyboard or STDIN.
Example: echo 'SELECT * FROM foo;' | sql mysql:///
--db-size
--dbsize Size of database. Show the size of the database on
disk. For Oracle this requires access to read the
table dba_data_files - the user system has that.
--help
-h Print a summary of the options to GNU sql and exit.
--html HTML output. Turn on HTML tabular output.
20121122 Last change: 2014-06-17 1
parallel SQL(1)
--show-processlist
--proclist
--listproc
Show the list of running queries.
--show-databases
--showdbs
--list-databases
--listdbs
List the databases (table spaces) in the database.
--show-tables
--list-tables
--table-list
List the tables in the database.
--noheaders
--no-headers
-n Remove headers and footers and print only tuples.
Bug in Oracle: it still prints number of rows
found.
-p pass-through
The string following -p will be given to the
database connection program as arguments. Multiple
-p's will be joined with space. Example: pass '-U'
and the user name to the program:
-p "-U scott" can also be written -p -U -p scott.
-r Try 3 times. Short version of --retries 3.
--retries ntimes
Try ntimes times. If the client program returns
with an error, retry the command. Default is
--retries 1.
--sep string
-s string
Field separator. Use string as separator between
columns.
--skip-first-line
Do not use the first line of input (used by GNU sql
itself when called with --shebang).
--table-size
--tablesize
Size of tables. Show the size of the tables in the
database.
--version
20121122 Last change: 2014-06-17 2
parallel SQL(1)
-V Print the version GNU sql and exit.
--shebang
-Y GNU sql can be called as a shebang (#!) command as
the first line of a script. Like this:
#!/usr/bin/sql -Y mysql:///
SELECT * FROM foo;
For this to work --shebang or -Y must be set as the
first option.
DBURL
To quote special characters use %-encoding specified in
http://tools.ietf.org/html/rfc3986#section-2.1 (E.g. a
password containing '/' would contain '%2F').
Examples:
mysql://scott:tiger@my.example.com/mydb
sql:oracle://scott:tiger@ora.example.com/xe
postgresql://scott:tiger@pg.example.com/pgdb
pg:///
postgresqlssl://scott@pg.example.com:3333/pgdb
sql:sqlite2:////tmp/db.sqlite?SELECT * FROM foo;
sqlite3:///../db.sqlite3?SELECT%20*%20FROM%20foo;
Currently supported vendors: MySQL (mysql), MySQL with SSL
(mysqls, mysqlssl), Oracle (oracle, ora), PostgreSQL
(postgresql, pg, pgsql, postgres), PostgreSQL with SSL
(postgresqlssl, pgs, pgsqlssl, postgresssl, pgssl,
postgresqls, pgsqls, postgress), SQLite2 (sqlite, sqlite2),
SQLite3 (sqlite3).
Aliases must start with ':' and are read from
/etc/sql/aliases and ~/.sql/aliases. The user's own
~/.sql/aliases should only be readable by the user.
Example of aliases:
20121122 Last change: 2014-06-17 3
parallel SQL(1)
:myalias1 pg://scott:tiger@pg.example.com/pgdb
:myalias2 ora://scott:tiger@ora.example.com/xe
# Short form of mysql://`whoami`:nopassword@localhost:3306/`whoami`
:myalias3 mysql:///
# Short form of mysql://`whoami`:nopassword@localhost:33333/mydb
:myalias4 mysql://:33333/mydb
# Alias for an alias
:m :myalias4
# the sortest alias possible
: sqlite2:////tmp/db.sqlite
# Including an SQL query
:query sqlite:////tmp/db.sqlite?SELECT * FROM foo;
EXAMPLES
Get an interactive prompt
The most basic use of GNU sql is to get an interactive
prompt:
sql sql:oracle://scott:tiger@ora.example.com/xe
If you have setup an alias you can do:
sql :myora
Run a query
To run a query directly from the command line:
sql :myalias "SELECT * FROM foo;"
Oracle requires newlines after each statement. This can be
done like this:
sql :myora "SELECT * FROM foo;" "SELECT * FROM bar;"
Or this:
sql :myora "SELECT * FROM foo;\nSELECT * FROM bar;"
Copy a PostgreSQL database
To copy a PostgreSQL database use pg_dump to generate the
dump and GNU sql to import it:
pg_dump pg_database | sql
Empty all tables in a MySQL database
Using GNU parallel it is easy to empty all tables without
dropping them:
sql -n mysql:/// 'show tables' | parallel sql mysql:///
DELETE FROM {};
20121122 Last change: 2014-06-17 4
parallel SQL(1)
Drop all tables in a PostgreSQL database
To drop all tables in a PostgreSQL database do:
sql -n pg:/// '\dt' | parallel --colsep '\|' -r sql pg:///
DROP TABLE {2};
Run as a script
Instead of doing:
sql mysql:/// < sqlfile
you can combine the sqlfile with the DBURL to make a UNIX-
script. Create a script called demosql:
SELECT * FROM foo;
Then do:
chmod +x demosql; ./demosql
Use --colsep to process multiple columns
Use GNU parallel's --colsep to separate columns:
sql -s '\t' :myalias 'SELECT * FROM foo;' | parallel
--colsep '\t' do_stuff {4} {1}
Retry if the connection fails
If the access to the database fails occationally --retries
can help make sure the query succeeds:
sql --retries 5 :myalias 'SELECT * FROM really_big_foo;'
Get info about the running database system
Show how big the database is:
sql --db-size :myalias
List the tables:
sql --list-tables :myalias
List the size of the tables:
sql --table-size :myalias
List the running processes:
sql --show-processlist :myalias
20121122 Last change: 2014-06-17 5
parallel SQL(1)
REPORTING BUGS
GNU sql is part of GNU parallel. Report bugs to
<bug-parallel@gnu.org>.
AUTHOR
When using GNU sql for a publication please cite:
O. Tange (2011): GNU SQL - A Command Line Tool for Accessing
Different Databases Using DBURLs, ;login: The USENIX
Magazine, April 2011:29-32.
Copyright (C) 2008,2009,2010 Ole Tange http://ole.tange.dk
Copyright (C) 2010,2011 Ole Tange, http://ole.tange.dk and
Free Software Foundation, Inc.
LICENSE
Copyright (C) 2007,2008,2009,2010,2011 Free Software
Foundation, Inc.
This program is free software; you can redistribute it
and/or modify it under the terms of the GNU General Public
License as published by the Free Software Foundation; either
version 3 of the License, or at your option any later
version.
This program is distributed in the hope that it will be
useful, but WITHOUT ANY WARRANTY; without even the implied
warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE. See the GNU General Public License for more
details.
You should have received a copy of the GNU General Public
License along with this program. If not, see
<http://www.gnu.org/licenses/>.
Documentation license I
Permission is granted to copy, distribute and/or modify this
documentation under the terms of the GNU Free Documentation
License, Version 1.3 or any later version published by the
Free Software Foundation; with no Invariant Sections, with
no Front-Cover Texts, and with no Back-Cover Texts. A copy
of the license is included in the file fdl.txt.
Documentation license II
You are free:
to Share to copy, distribute and transmit the work
to Remix to adapt the work
20121122 Last change: 2014-06-17 6
parallel SQL(1)
Under the following conditions:
Attribution
You must attribute the work in the manner specified
by the author or licensor (but not in any way that
suggests that they endorse you or your use of the
work).
Share Alike
If you alter, transform, or build upon this work,
you may distribute the resulting work only under
the same, similar or a compatible license.
With the understanding that:
Waiver Any of the above conditions can be waived if you
get permission from the copyright holder.
Public Domain
Where the work or any of its elements is in the
public domain under applicable law, that status is
in no way affected by the license.
Other Rights
In no way are any of the following rights affected
by the license:
o Your fair dealing or fair use rights, or
other applicable copyright exceptions and
limitations;
o The author's moral rights;
o Rights other persons may have either in
the work itself or in how the work is
used, such as publicity or privacy rights.
Notice For any reuse or distribution, you must make clear
to others the license terms of this work.
A copy of the full license is included in the file as
cc-by-sa.txt.
DEPENDENCIES
GNU sql uses Perl. If mysql is installed, MySQL dburls will
work. If psql is installed, PostgreSQL dburls will work. If
sqlite is installed, SQLite2 dburls will work. If sqlite3
is installed, SQLite3 dburls will work. If sqlplus is
installed, Oracle dburls will work. If rlwrap is installed,
GNU sql will have a command history for Oracle.
20121122 Last change: 2014-06-17 7
parallel SQL(1)
FILES
~/.sql/aliases - user's own aliases with DBURLs
/etc/sql/aliases - common aliases with DBURLs
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | shell/parallel |
|Stability | Uncommitted |
SEE ALSO
mysql(1), psql(1), rlwrap(1), sqlite(1), sqlite3(1),
sqlplus(1)
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from
http://ftp.gnu.org/gnu/parallel/parallel-20121122.tar.bz2
Further information about this software can be found on the
open source community website at
http://www.gnu.org/software/parallel/.
20121122 Last change: 2014-06-17 8
