my_print_defaults
(1)
Name
my_print_defaults - display options from option files
Synopsis
my_print_defaults [options] option_group ...
Description
MySQL Database System MY_PRINT_DEFAULTS(1)
NAME
SYNOPSIS
DESCRIPTION
my_print_defaults displays the options that are present in
option groups of option files. The output indicates what
options will be used by programs that read the specified
option groups. For example, the mysqlcheck program reads the
[mysqlcheck] and [client] option groups. To see what options
are present in those groups in the standard option files,
invoke my_print_defaults like this:
shell> my_print_defaults mysqlcheck client
--user=myusername
--password=secret
--host=localhost
The output consists of options, one per line, in the form
that they would be specified on the command line.
my_print_defaults supports the following options.
o --help, -?
Display a help message and exit.
o --config-file=file_name, --defaults-file=file_name, -c
file_name
Read only the given option file.
o --debug=debug_options, -# debug_options
Write a debugging log. A typical debug_options string is
'd:t:o,file_name'. The default is
'd:t:o,/tmp/my_print_defaults.trace'.
o --defaults-extra-file=file_name, --extra-file=file_name,
-e file_name
Read this option file after the global option file but
(on Unix) before the user option file.
o --defaults-group-suffix=suffix, -g suffix
In addition to the groups named on the command line,
read groups that have the given suffix.
o --no-defaults, -n
MySQL 5.5 Last change: 03/22/2013 1
Return an empty string.
o --verbose, -v
Verbose mode. Print more information about what the
program does.
o --version, -V
Display version information and exit.
COPYRIGHT
Copyright (C) 1997, 2013, Oracle and/or its affiliates. All
rights reserved.
This software and related documentation are provided under a
license agreement containing restrictions on use and
disclosure and are protected by intellectual property laws.
Except as expressly permitted in your license agreement or
allowed by law, you may not use, copy, reproduce, translate,
broadcast, modify, license, transmit, distribute, exhibit,
perform, publish, or display any part, in any form, or by
any means. Reverse engineering, disassembly, or
decompilation of this software, unless required by law for
interoperability, is prohibited.
The information contained herein is subject to change
without notice and is not warranted to be error-free. If you
find any errors, please report them to us in writing.
If this software or related documentation is delivered to
the U.S. Government or anyone licensing it on behalf of the
U.S. Government, the following notice is applicable:
U.S. GOVERNMENT RIGHTS Programs, software, databases, and
related documentation and technical data delivered to U.S.
Government customers are "commercial computer software" or
"commercial technical data" pursuant to the applicable
Federal Acquisition Regulation and agency-specific
supplemental regulations. As such, the use, duplication,
disclosure, modification, and adaptation shall be subject to
the restrictions and license terms set forth in the
applicable Government contract, and, to the extent
applicable by the terms of the Government contract, the
additional rights set forth in FAR 52.227-19, Commercial
Computer Software License (December 2007). Oracle USA, Inc.,
500 Oracle Parkway, Redwood City, CA 94065.
This software is developed for general use in a variety of
information management applications. It is not developed or
intended for use in any inherently dangerous applications,
including applications which may create a risk of personal
MySQL 5.5 Last change: 03/22/2013 2
injury. If you use this software in dangerous applications,
then you shall be responsible to take all appropriate fail-
safe, backup, redundancy, and other measures to ensure the
safe use of this software. Oracle Corporation and its
affiliates disclaim any liability for any damages caused by
use of this software in dangerous applications.
Oracle is a registered trademark of Oracle Corporation
and/or its affiliates. MySQL is a trademark of Oracle
Corporation and/or its affiliates, and shall not be used
without Oracle's express written authorization. Other names
may be trademarks of their respective owners.
This software and documentation may provide access to or
information on content, products, and services from third
parties. Oracle Corporation and its affiliates are not
responsible for and expressly disclaim all warranties of any
kind with respect to third-party content, products, and
services. Oracle Corporation and its affiliates will not be
responsible for any loss, costs, or damages incurred due to
your access to or use of third-party content, products, or
services.
This document in any form, software or printed matter,
contains proprietary information that is the exclusive
property of Oracle. Your access to and use of this material
is subject to the terms and conditions of your Oracle
Software License and Service Agreement, which has been
executed and with which you agree to comply. This document
and information contained herein may not be disclosed,
copied, reproduced, or distributed to anyone outside Oracle
without prior written consent of Oracle or as specifically
provided below. This document is not part of your license
agreement nor can it be incorporated into any contractual
agreement with Oracle or its subsidiaries or affiliates.
This documentation is NOT distributed under a GPL license.
Use of this documentation is subject to the following terms:
You may create a printed copy of this documentation solely
for your own personal use. Conversion to other formats is
allowed as long as the actual content is not altered or
edited in any way. You shall not publish or distribute this
documentation in any form or on any media, except if you
distribute the documentation in a manner similar to how
Oracle disseminates it (that is, electronically for download
on a Web site with the software) or on a CD-ROM or similar
medium, provided however that the documentation is
disseminated together with the software on the same medium.
Any other use, such as any dissemination of printed copies
or use of this documentation, in whole or in part, in
another publication, requires the prior written consent from
MySQL 5.5 Last change: 03/22/2013 3
an authorized representative of Oracle. Oracle and/or its
affiliates reserve any and all rights to this documentation
not expressly granted above.
For more information on the terms of this license, or for
details on how the MySQL documentation is built and
produced, please visit blue]MySQL Contact & Questions].
For additional licensing information, including licenses for
third-party libraries used by MySQL products, see Preface
and Legal Notices.
For help with using MySQL, please visit either the
blue]MySQL Forums] or blue]MySQL Mailing Lists] where you
can discuss your issues with other MySQL users.
For additional documentation on MySQL products, including
translations of the documentation into other languages, and
downloadable versions in variety of formats, including HTML
and PDF formats, see the blue]MySQL Documentation Library].
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | database/mysql-55 |
|Stability | Uncommitted |
SEE ALSO
For more information, please refer to the MySQL Reference
Manual, which may already be installed locally and which is
also available online at http://dev.mysql.com/doc/.
AUTHOR
Oracle Corporation (http://dev.mysql.com/).
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from
http://downloads.mysql.com/archives/mysql-5.5/mysql-5.5.31.tar.gz
Further information about this software can be found on the
open source community website at http://dev.mysql.com/.
MySQL 5.5 Last change: 03/22/2013 4
