git-parse-remote
(1)
Name
git-parse-remote - Routines to help parsing remote
repository access parameters
Synopsis
. "$(git --exec-path)/git-parse-remote"
Description
Git Manual GIT-PARSE-REMOTE(1)
NAME
SYNOPSIS
DESCRIPTION
This script is included in various scripts to supply
routines to parse files under $GIT_DIR/remotes/ and
$GIT_DIR/branches/ and configuration variables that are
related to fetching, pulling and pushing.
GIT
Part of the git(1) suite
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | developer/versioning/git |
|Stability | Uncommitted |
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from http://git-
core.googlecode.com/files/git-1.7.9.2.tar.gz
Further information about this software can be found on the
open source community website at http://git-scm.com/.
Git 1.7.9.2 Last change: 02/22/2012 1
