rpm2cpio [file.rpm]
The rpm2cpio utility converts the .rpm file specified as its sole argument to a cpio archive on standard output. (See NOTES.) If no argument is given, an rpm stream is read from standard input. In both cases, rpm2cpio will fail and print a usage message if the standard output is a terminal. Therefore, the output is usually redirected to a file or piped through the cpio(1) utility.
example% rpm2cpio Device3Dfx-1.1-2.src.rpm | cpio -itv CPIO archive found! -rw-r--r-- 1 root root 2635 Sep 13 16:39 1998, 3dfx.gif -rw-r--r-- 1 root root 11339 Sep 27 16:03 1998, Dev3Dfx.tar.gz -rw-r--r-- 1 root root 1387 Sep 27 16:04 1998, Device3Dfx-1.1-2.spec 31 blocksExample 2 Converting from standard input
example% rpm2cpio < Device3Dfx-1.1-2.src.rpm | cpio -itv CPIO archive found! -rw-r--r-- 1 root root 2635 Sep 13 16:39 1998, 3dfx.gif -rw-r--r-- 1 root root 11339 Sep 27 16:03 1998, Dev3Dfx.tar.gz -rw-r--r-- 1 root root 1387 Sep 27 16:04 1998, Device3Dfx-1.1-2.spec 31 blocks
rpm2cpio handles versions 3 and 4 RPMs.
