git-diff-index
(1)
Name
git-diff-index - Compares content and mode of blobs between
the index and repository
Synopsis
git diff-index [-m] [--cached] [<common diff options>] <tree-ish> [<path>...]
Description
Git Manual GIT-DIFF-INDEX(1)
NAME
SYNOPSIS
DESCRIPTION
Compares the content and mode of the blobs found via a tree
object with the content of the current index and, optionally
ignoring the stat state of the file on disk. When paths are
specified, compares only those named paths. Otherwise all
entries in the index are compared.
OPTIONS
-p, -u, --patch
Generate patch (see section on generating patches).
-U<n>, --unified=<n>
Generate diffs with <n> lines of context instead of the
usual three. Implies -p.
--raw
Generate the raw format. This is the default.
--patch-with-raw
Synonym for -p --raw.
--minimal
Spend extra time to make sure the smallest possible diff
is produced.
--patience
Generate a diff using the "patience diff" algorithm.
--stat[=<width>[,<name-width>[,<count>]]]
Generate a diffstat. You can override the default output
width for 80-column terminal by --stat=<width>. The
width of the filename part can be controlled by giving
another width to it separated by a comma. By giving a
third parameter <count>, you can limit the output to the
first <count> lines, followed by ... if there are more.
These parameters can also be set individually with
--stat-width=<width>, --stat-name-width=<name-width> and
--stat-count=<count>.
--numstat
Similar to --stat, but shows number of added and deleted
lines in decimal notation and pathname without
abbreviation, to make it more machine friendly. For
Git 1.7.9.2 Last change: 02/22/2012 1
binary files, outputs two - instead of saying 0 0.
--shortstat
Output only the last line of the --stat format
containing total number of modified files, as well as
number of added and deleted lines.
--dirstat[=<param1,param2,...>]
Output the distribution of relative amount of changes
for each sub-directory. The behavior of --dirstat can be
customized by passing it a comma separated list of
parameters. The defaults are controlled by the
diff.dirstat configuration variable (see git-config(1)).
The following parameters are available:
changes
Compute the dirstat numbers by counting the lines
that have been removed from the source, or added to
the destination. This ignores the amount of pure
code movements within a file. In other words,
rearranging lines in a file is not counted as much
as other changes. This is the default behavior when
no parameter is given.
lines
Compute the dirstat numbers by doing the regular
line-based diff analysis, and summing the
removed/added line counts. (For binary files, count
64-byte chunks instead, since binary files have no
natural concept of lines). This is a more expensive
--dirstat behavior than the changes behavior, but it
does count rearranged lines within a file as much as
other changes. The resulting output is consistent
with what you get from the other --*stat options.
files
Compute the dirstat numbers by counting the number
of files changed. Each changed file counts equally
in the dirstat analysis. This is the computationally
cheapest --dirstat behavior, since it does not have
to look at the file contents at all.
cumulative
Count changes in a child directory for the parent
directory as well. Note that when using cumulative,
the sum of the percentages reported may exceed 100%.
The default (non-cumulative) behavior can be
specified with the noncumulative parameter.
<limit>
An integer parameter specifies a cut-off percent (3%
by default). Directories contributing less than this
Git 1.7.9.2 Last change: 02/22/2012 2
percentage of the changes are not shown in the
output.
Example: The following will count changed files, while
ignoring directories with less than 10% of the total
amount of changed files, and accumulating child
directory counts in the parent directories:
--dirstat=files,10,cumulative.
--summary
Output a condensed summary of extended header
information such as creations, renames and mode changes.
--patch-with-stat
Synonym for -p --stat.
-z
When --raw, --numstat, --name-only or --name-status has
been given, do not munge pathnames and use NULs as
output field terminators.
Without this option, each pathname output will have TAB,
LF, double quotes, and backslash characters replaced
with \t, \n, \", and \\, respectively, and the pathname
will be enclosed in double quotes if any of those
replacements occurred.
--name-only
Show only names of changed files.
--name-status
Show only names and status of changed files. See the
description of the --diff-filter option on what the
status letters mean.
--submodule[=<format>]
Chose the output format for submodule differences.
<format> can be one of short and log. short just shows
pairs of commit names, this format is used when this
option is not given. log is the default value for this
option and lists the commits in that commit range like
the summary option of git-submodule(1) does.
--color[=<when>]
Show colored diff. The value must be always (the default
for <when>), never, or auto. The default value is never.
--no-color
Turn off colored diff. It is the same as --color=never.
--word-diff[=<mode>]
Show a word diff, using the <mode> to delimit changed
Git 1.7.9.2 Last change: 02/22/2012 3
words. By default, words are delimited by whitespace;
see --word-diff-regex below. The <mode> defaults to
plain, and must be one of:
color
Highlight changed words using only colors. Implies
--color.
plain
Show words as [-removed-] and {added}. Makes no
attempts to escape the delimiters if they appear in
the input, so the output may be ambiguous.
porcelain
Use a special line-based format intended for script
consumption. Added/removed/unchanged runs are
printed in the usual unified diff format, starting
with a +/-/` ` character at the beginning of the
line and extending to the end of the line. Newlines
in the input are represented by a tilde ~ on a line
of its own.
none
Disable word diff again.
Note that despite the name of the first mode, color is
used to highlight the changed parts in all modes if
enabled.
--word-diff-regex=<regex>
Use <regex> to decide what a word is, instead of
considering runs of non-whitespace to be a word. Also
implies --word-diff unless it was already enabled.
Every non-overlapping match of the <regex> is considered
a word. Anything between these matches is considered
whitespace and ignored(!) for the purposes of finding
differences. You may want to append |[^[:space:]] to
your regular expression to make sure that it matches all
non-whitespace characters. A match that contains a
newline is silently truncated(!) at the newline.
The regex can also be set via a diff driver or
configuration option, see gitattributes(1) or git-
config(1). Giving it explicitly overrides any diff
driver or configuration setting. Diff drivers override
configuration settings.
--color-words[=<regex>]
Equivalent to --word-diff=color plus (if a regex was
specified) --word-diff-regex=<regex>.
Git 1.7.9.2 Last change: 02/22/2012 4
--no-renames
Turn off rename detection, even when the configuration
file gives the default to do so.
--check
Warn if changes introduce whitespace errors. What are
considered whitespace errors is controlled by
core.whitespace configuration. By default, trailing
whitespaces (including lines that solely consist of
whitespaces) and a space character that is immediately
followed by a tab character inside the initial indent of
the line are considered whitespace errors. Exits with
non-zero status if problems are found. Not compatible
with --exit-code.
--full-index
Instead of the first handful of characters, show the
full pre- and post-image blob object names on the
"index" line when generating patch format output.
--binary
In addition to --full-index, output a binary diff that
can be applied with git-apply.
--abbrev[=<n>]
Instead of showing the full 40-byte hexadecimal object
name in diff-raw format output and diff-tree header
lines, show only a partial prefix. This is independent
of the --full-index option above, which controls the
diff-patch output format. Non default number of digits
can be specified with --abbrev=<n>.
-B[<n>][/<m>], --break-rewrites[=[<n>][/<m>]]
Break complete rewrite changes into pairs of delete and
create. This serves two purposes:
It affects the way a change that amounts to a total
rewrite of a file not as a series of deletion and
insertion mixed together with a very few lines that
happen to match textually as the context, but as a
single deletion of everything old followed by a single
insertion of everything new, and the number m controls
this aspect of the -B option (defaults to 60%). -B/70%
specifies that less than 30% of the original should
remain in the result for git to consider it a total
rewrite (i.e. otherwise the resulting patch will be a
series of deletion and insertion mixed together with
context lines).
When used with -M, a totally-rewritten file is also
considered as the source of a rename (usually -M only
considers a file that disappeared as the source of a
Git 1.7.9.2 Last change: 02/22/2012 5
rename), and the number n controls this aspect of the -B
option (defaults to 50%). -B20% specifies that a change
with addition and deletion compared to 20% or more of
the file's size are eligible for being picked up as a
possible source of a rename to another file.
-M[<n>], --find-renames[=<n>]
Detect renames. If n is specified, it is a threshold on
the similarity index (i.e. amount of addition/deletions
compared to the file's size). For example, -M90% means
git should consider a delete/add pair to be a rename if
more than 90% of the file hasn't changed.
-C[<n>], --find-copies[=<n>]
Detect copies as well as renames. See also
--find-copies-harder. If n is specified, it has the same
meaning as for -M<n>.
For performance reasons, by default, -C option finds
copies only if the original file of the copy was
modified in the same changeset. This flag makes the
command inspect unmodified files as candidates for the
source of copy. This is a very expensive operation for
large projects, so use it with caution. Giving more than
one -C option has the same effect.
-D, --irreversible-delete
Omit the preimage for deletes, i.e. print only the
header but not the diff between the preimage and
/dev/null. The resulting patch is not meant to be
applied with patch nor git apply; this is solely for
people who want to just concentrate on reviewing the
text after the change. In addition, the output obviously
lack enough information to apply such a patch in
reverse, even manually, hence the name of the option.
When used together with -B, omit also the preimage in
the deletion part of a delete/create pair.
-l<num>
The -M and -C options require O(n^2) processing time
where n is the number of potential rename/copy targets.
This option prevents rename/copy detection from running
if the number of rename/copy targets exceeds the
specified number.
--diff-filter=[(A|C|D|M|R|T|U|X|B)...[*]]
Select only files that are Added (A), Copied (C),
Deleted (D), Modified (M), Renamed (R), have their type
(i.e. regular file, symlink, submodule, ...) changed
(T), are Unmerged (U), are Unknown (X), or have had
Git 1.7.9.2 Last change: 02/22/2012 6
their pairing Broken (B). Any combination of the filter
characters (including none) can be used. When *
(All-or-none) is added to the combination, all paths are
selected if there is any file that matches other
criteria in the comparison; if there is no file that
matches other criteria, nothing is selected.
-S<string>
Look for differences that introduce or remove an
instance of <string>. Note that this is different than
the string simply appearing in diff output; see the
pickaxe entry in gitdiffcore(5) for more details.
-G<regex>
Look for differences whose added or removed line matches
the given <regex>.
--pickaxe-all
When -S or -G finds a change, show all the changes in
that changeset, not just the files that contain the
change in <string>.
--pickaxe-regex
Make the <string> not a plain string but an extended
POSIX regex to match.
-O<orderfile>
Output the patch in the order specified in the
<orderfile>, which has one shell glob pattern per line.
-R
Swap two inputs; that is, show differences from index or
on-disk file to tree contents.
--relative[=<path>]
When run from a subdirectory of the project, it can be
told to exclude changes outside the directory and show
pathnames relative to it with this option. When you are
not in a subdirectory (e.g. in a bare repository), you
can name which subdirectory to make the output relative
to by giving a <path> as an argument.
-a, --text
Treat all files as text.
--ignore-space-at-eol
Ignore changes in whitespace at EOL.
-b, --ignore-space-change
Ignore changes in amount of whitespace. This ignores
whitespace at line end, and considers all other
sequences of one or more whitespace characters to be
Git 1.7.9.2 Last change: 02/22/2012 7
equivalent.
-w, --ignore-all-space
Ignore whitespace when comparing lines. This ignores
differences even if one line has whitespace where the
other line has none.
--inter-hunk-context=<lines>
Show the context between diff hunks, up to the specified
number of lines, thereby fusing hunks that are close to
each other.
-W, --function-context
Show whole surrounding functions of changes.
--exit-code
Make the program exit with codes similar to diff(1).
That is, it exits with 1 if there were differences and 0
means no differences.
--quiet
Disable all output of the program. Implies --exit-code.
--ext-diff
Allow an external diff helper to be executed. If you set
an external diff driver with gitattributes(4), you need
to use this option with git-log(1) and friends.
--no-ext-diff
Disallow external diff drivers.
--textconv, --no-textconv
Allow (or disallow) external text conversion filters to
be run when comparing binary files. See gitattributes(4)
for details. Because textconv filters are typically a
one-way conversion, the resulting diff is suitable for
human consumption, but cannot be applied. For this
reason, textconv filters are enabled by default only for
git-diff(1) and git-log(1), but not for git-format-
patch(1) or diff plumbing commands.
--ignore-submodules[=<when>]
Ignore changes to submodules in the diff generation.
<when> can be either "none", "untracked", "dirty" or
"all", which is the default Using "none" will consider
the submodule modified when it either contains untracked
or modified files or its HEAD differs from the commit
recorded in the superproject and can be used to override
any settings of the ignore option in git-config(1) or
gitmodules(4). When "untracked" is used submodules are
not considered dirty when they only contain untracked
content (but they are still scanned for modified
Git 1.7.9.2 Last change: 02/22/2012 8
content). Using "dirty" ignores all changes to the work
tree of submodules, only changes to the commits stored
in the superproject are shown (this was the behavior
until 1.7.0). Using "all" hides all changes to
submodules.
--src-prefix=<prefix>
Show the given source prefix instead of "a/".
--dst-prefix=<prefix>
Show the given destination prefix instead of "b/".
--no-prefix
Do not show any source or destination prefix.
For more detailed explanation on these common options, see
also gitdiffcore(5).
<tree-ish>
The id of a tree object to diff against.
--cached
do not consider the on-disk file at all
-m
By default, files recorded in the index but not checked
out are reported as deleted. This flag makes git
diff-index say that all non-checked-out files are up to
date.
RAW OUTPUT FORMAT
The raw output format from "git-diff-index",
"git-diff-tree", "git-diff-files" and "git diff --raw" are
very similar.
These commands all compare two sets of things; what is
compared differs:
git-diff-index <tree-ish>
compares the <tree-ish> and the files on the filesystem.
git-diff-index --cached <tree-ish>
compares the <tree-ish> and the index.
git-diff-tree [-r] <tree-ish-1> <tree-ish-2> [<pattern>...]
compares the trees named by the two arguments.
git-diff-files [<pattern>...]
compares the index and the files on the filesystem.
The "git-diff-tree" command begins its output by printing
the hash of what is being compared. After that, all the
Git 1.7.9.2 Last change: 02/22/2012 9
commands print one output line per changed file.
An output line is formatted this way:
in-place edit :100644 100644 bcd1234... 0123456... M file0
copy-edit :100644 100644 abcd123... 1234567... C68 file1 file2
rename-edit :100644 100644 abcd123... 1234567... R86 file1 file3
create :000000 100644 0000000... 1234567... A file4
delete :100644 000000 1234567... 0000000... D file5
unmerged :000000 000000 0000000... 0000000... U file6
That is, from the left to the right:
1. a colon.
2. mode for "src"; 000000 if creation or unmerged.
3. a space.
4. mode for "dst"; 000000 if deletion or unmerged.
5. a space.
6. sha1 for "src"; 0{40} if creation or unmerged.
7. a space.
8. sha1 for "dst"; 0{40} if creation, unmerged or "look at
work tree".
9. a space.
10. status, followed by optional "score" number.
11. a tab or a NUL when -z option is used.
12. path for "src"
13. a tab or a NUL when -z option is used; only exists for C
or R.
14. path for "dst"; only exists for C or R.
15. an LF or a NUL when -z option is used, to terminate the
record.
Possible status letters are:
o A: addition of a file
o C: copy of a file into a new one
Git 1.7.9.2 Last change: 02/22/2012 10
o D: deletion of a file
o M: modification of the contents or mode of a file
o R: renaming of a file
o T: change in the type of the file
o U: file is unmerged (you must complete the merge before
it can be committed)
o X: "unknown" change type (most probably a bug, please
report it)
Status letters C and R are always followed by a score
(denoting the percentage of similarity between the source
and target of the move or copy), and are the only ones to be
so.
<sha1> is shown as all 0's if a file is new on the
filesystem and it is out of sync with the index.
Example:
:100644 100644 5be4a4...... 000000...... M file.c
When -z option is not used, TAB, LF, and backslash
characters in pathnames are represented as \t, \n, and \\,
respectively.
DIFF FORMAT FOR MERGES
"git-diff-tree", "git-diff-files" and "git-diff --raw" can
take -c or --cc option to generate diff output also for
merge commits. The output differs from the format described
above in the following way:
1. there is a colon for each parent
2. there are more "src" modes and "src" sha1
3. status is concatenated status characters for each parent
4. no optional "score" number
5. single path, only for "dst"
Example:
::100644 100644 100644 fabadb8... cc95eb0... 4866510... MM describe.c
Git 1.7.9.2 Last change: 02/22/2012 11
Note that combined diff lists only files which were modified
from all parents.
GENERATING PATCHES WITH -P
When "git-diff-index", "git-diff-tree", or "git-diff-files"
are run with a -p option, "git diff" without the --raw
option, or "git log" with the "-p" option, they do not
produce the output described above; instead they produce a
patch file. You can customize the creation of such patches
via the GIT_EXTERNAL_DIFF and the GIT_DIFF_OPTS environment
variables.
What the -p option produces is slightly different from the
traditional diff format:
1. It is preceded with a "git diff" header that looks like
this:
diff --git a/file1 b/file2
The a/ and b/ filenames are the same unless rename/copy
is involved. Especially, even for a creation or a
deletion, /dev/null is not used in place of the a/ or b/
filenames.
When rename/copy is involved, file1 and file2 show the
name of the source file of the rename/copy and the name
of the file that rename/copy produces, respectively.
2. It is followed by one or more extended header lines:
old mode <mode>
new mode <mode>
deleted file mode <mode>
new file mode <mode>
copy from <path>
copy to <path>
rename from <path>
rename to <path>
similarity index <number>
dissimilarity index <number>
index <hash>..<hash> <mode>
File modes are printed as 6-digit octal numbers
including the file type and file permission bits.
Path names in extended headers do not include the a/ and
b/ prefixes.
The similarity index is the percentage of unchanged
lines, and the dissimilarity index is the percentage of
changed lines. It is a rounded down integer, followed by
Git 1.7.9.2 Last change: 02/22/2012 12
a percent sign. The similarity index value of 100% is
thus reserved for two equal files, while 100%
dissimilarity means that no line from the old file made
it into the new one.
The index line includes the SHA-1 checksum before and
after the change. The <mode> is included if the file
mode does not change; otherwise, separate lines indicate
the old and the new mode.
3. TAB, LF, double quote and backslash characters in
pathnames are represented as \t, \n, \" and \\,
respectively. If there is need for such substitution
then the whole pathname is put in double quotes.
4. All the file1 files in the output refer to files before
the commit, and all the file2 files refer to files after
the commit. It is incorrect to apply each change to each
file sequentially. For example, this patch will swap a
and b:
diff --git a/a b/b
rename from a
rename to b
diff --git a/b b/a
rename from b
rename to a
COMBINED DIFF FORMAT
Any diff-generating command can take the `-c` or --cc option
to produce a combined diff when showing a merge. This is the
default format when showing merges with git-diff(1) or git-
show(1). Note also that you can give the `-m' option to any
of these commands to force generation of diffs with
individual parents of a merge.
A combined diff format looks like this:
diff --combined describe.c
index fabadb8,cc95eb0..4866510
--- a/describe.c
+++ b/describe.c
@@@ -98,20 -98,12 +98,20 @@@
return (a_date > b_date) ? -1 : (a_date == b_date) ? 0 : 1;
- static void describe(char *arg)
-static void describe(struct commit *cmit, int last_one)
++static void describe(char *arg, int last_one)
+ unsigned char sha1[20];
+ struct commit *cmit;
Git 1.7.9.2 Last change: 02/22/2012 13
struct commit_list *list;
static int initialized = 0;
struct commit_name *n;
+ if (get_sha1(arg, sha1) < 0)
+ usage(describe_usage);
+ cmit = lookup_commit_reference(sha1);
+ if (!cmit)
if (!initialized) {
initialized = 1;
for_each_ref(get_name);
1. It is preceded with a "git diff" header, that looks like
this (when -c option is used):
diff --combined file
or like this (when --cc option is used):
diff --cc file
(this example shows a merge with two parents):
index <hash>,<hash>..<hash>
mode <mode>,<mode>..<mode>
deleted file mode <mode>,<mode>
The mode <mode>,<mode>..<mode> line appears only if at
least one of the <mode> is different from the rest.
Extended headers with information about detected
contents movement (renames and copying detection) are
designed to work with diff of two <tree-ish> and are not
used by combined diff format.
3. It is followed by two-line from-file/to-file header
--- a/file
+++ b/file
Similar to two-line header for traditional unified diff
format, /dev/null is used to signal created or deleted
files.
4. Chunk header format is modified to prevent people from
accidentally feeding it to patch -p1. Combined diff
format was created for review of merge commit changes,
Git 1.7.9.2 Last change: 02/22/2012 14
and was not meant for apply. The change is similar to
the change in the extended index header:
@@@ <from-file-range> <from-file-range> <to-file-range> @@@
There are (number of parents + 1) @ characters in the
chunk header for combined diff format.
Unlike the traditional unified diff format, which shows two
files A and B with a single column that has - (minus --
appears in A but removed in B), + (plus -- missing in A but
added to B), or " " (space -- unchanged) prefix, this format
compares two or more files file1, file2,... with one file X,
and shows how X differs from each of fileN. One column for
each of fileN is prepended to the output line to note how
X's line is different from it.
A - character in the column N means that the line appears in
fileN but it does not appear in the result. A + character in
the column N means that the line appears in the result, and
fileN does not have that line (in other words, the line was
added, from the point of view of that parent).
In the above example output, the function signature was
changed from both files (hence two - removals from both
file1 and file2, plus ++ to mean one line that was added
does not appear in either file1 nor file2). Also eight other
lines are the same from file1 but do not appear in file2
(hence prefixed with +).
When shown by git diff-tree -c, it compares the parents of a
merge commit with the merge result (i.e. file1..fileN are
the parents). When shown by git diff-files -c, it compares
the two unresolved merge parents with the working tree file
(i.e. file1 is stage 2 aka "our version", file2 is stage 3
aka "their version").
OTHER DIFF FORMATS
The --summary option describes newly added, deleted, renamed
and copied files. The --stat option adds diffstat(1) graph
to the output. These options can be combined with other
options, such as -p, and are meant for human consumption.
When showing a change that involves a rename or a copy,
--stat output formats the pathnames compactly by combining
common prefix and suffix of the pathnames. For example, a
change that moves arch/i386/Makefile to arch/x86/Makefile
while modifying 4 lines will be shown like this:
arch/{i386 => x86}/Makefile | 4 +--
Git 1.7.9.2 Last change: 02/22/2012 15
The --numstat option gives the diffstat(1) information but
is designed for easier machine consumption. An entry in
--numstat output looks like this:
1 2 README
3 1 arch/{i386 => x86}/Makefile
That is, from left to right:
1. the number of added lines;
2. a tab;
3. the number of deleted lines;
4. a tab;
5. pathname (possibly with rename/copy information);
6. a newline.
When -z output option is in effect, the output is formatted
this way:
1 2 README NUL
3 1 NUL arch/i386/Makefile NUL arch/x86/Makefile NUL
That is:
2. a tab;
4. a tab;
5. a NUL (only exists if renamed/copied);
6. pathname in preimage;
7. a NUL (only exists if renamed/copied);
8. pathname in postimage (only exists if renamed/copied);
9. a NUL.
The extra NUL before the preimage path in renamed case is to
allow scripts that read the output to tell if the current
record being read is a single-path record or a rename/copy
Git 1.7.9.2 Last change: 02/22/2012 16
record without reading ahead. After reading added and
deleted lines, reading up to NUL would yield the pathname,
but if that is NUL, the record will show two paths.
OPERATING MODES
You can choose whether you want to trust the index file
entirely (using the --cached flag) or ask the diff logic to
show any files that don't match the stat state as being
"tentatively changed". Both of these operations are very
useful indeed.
CACHED MODE
If --cached is specified, it allows you to ask:
show me the differences between HEAD and the current index
contents (the ones I'd write using 'git write-tree')
For example, let's say that you have worked on your working
directory, updated some files in the index and are ready to
commit. You want to see exactly what you are going to
commit, without having to write a new tree object and
compare it that way, and to do that, you just do
git diff-index --cached HEAD
Example: let's say I had renamed commit.c to git-commit.c,
and I had done an update-index to make that effective in the
index file. git diff-files wouldn't show anything at all,
since the index file matches my working directory. But doing
a git diff-index does:
torvalds@ppc970:~/git> git diff-index --cached HEAD
-100644 blob 4161aecc6700a2eb579e842af0b7f22b98443f74 commit.c
+100644 blob 4161aecc6700a2eb579e842af0b7f22b98443f74 git-commit.c
You can see easily that the above is a rename.
In fact, git diff-index --cached should always be entirely
equivalent to actually doing a git write-tree and comparing
that. Except this one is much nicer for the case where you
just want to check where you are.
So doing a git diff-index --cached is basically very useful
when you are asking yourself "what have I already marked for
being committed, and what's the difference to a previous
tree".
NON-CACHED MODE
The "non-cached" mode takes a different approach, and is
potentially the more useful of the two in that what it does
can't be emulated with a git write-tree + git diff-tree.
Thus that's the default mode. The non-cached version asks
Git 1.7.9.2 Last change: 02/22/2012 17
the question:
show me the differences between HEAD and the currently checked out
tree - index contents _and_ files that aren't up-to-date
which is obviously a very useful question too, since that
tells you what you could commit. Again, the output matches
the git diff-tree -r output to a tee, but with a twist.
The twist is that if some file doesn't match the index, we
don't have a backing store thing for it, and we use the
magic "all-zero" sha1 to show that. So let's say that you
have edited kernel/sched.c, but have not actually done a git
update-index on it yet - there is no "object" associated
with the new state, and you get:
torvalds@ppc970:~/v2.6/linux> git diff-index --abbrev HEAD
:100644 100664 7476bb... 000000... kernel/sched.c
i.e., it shows that the tree has changed, and that
kernel/sched.c has is not up-to-date and may contain new
stuff. The all-zero sha1 means that to get the real diff,
you need to look at the object in the working directory
directly rather than do an object-to-object diff.
Note
As with other commands of this type, git diff-index does
not actually look at the contents of the file at all. So
maybe kernel/sched.c hasn't actually changed, and it's
just that you touched it. In either case, it's a note
that you need to git update-index it to make the index
be in sync.
Note
You can have a mixture of files show up as "has been
updated" and "is still dirty in the working directory"
together. You can always tell which file is in which
state, since the "has been updated" ones show a valid
sha1, and the "not in sync with the index" ones will
always have the special all-zero sha1.
GIT
Part of the git(1) suite
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
Git 1.7.9.2 Last change: 02/22/2012 18
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | developer/versioning/git |
|Stability | Uncommitted |
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from http://git-
core.googlecode.com/files/git-1.7.9.2.tar.gz
Further information about this software can be found on the
open source community website at http://git-scm.com/.
Git 1.7.9.2 Last change: 02/22/2012 19
