info
(1)
Name
info - read Info documents
Synopsis
info [OPTION]... [MENU-ITEM...]
Description
User Commands INFO(1)
NAME
SYNOPSIS
DESCRIPTION
Read documentation in Info format.
OPTIONS
-k, --apropos=STRING
look up STRING in all indices of all manuals.
-d, --directory=DIR
add DIR to INFOPATH.
--dribble=FILENAME
remember user keystrokes in FILENAME.
-f, --file=FILENAME
specify Info file to visit.
-h, --help
display this help and exit.
--index-search=STRING
go to node pointed by index entry STRING.
-n, --node=NODENAME
specify nodes in first visited Info file.
-o, --output=FILENAME
output selected nodes to FILENAME.
-R, --raw-escapes
output "raw" ANSI escapes (default).
--no-raw-escapes
output escapes as literal text.
--restore=FILENAME
read initial keystrokes from FILENAME.
-O, --show-options, --usage
go to command-line options node.
--subnodes
recursively output menu items.
--vi-keys
use vi-like and less-like key bindings.
info 4.13 Last change: September 2008 1
--version
display version information and exit.
-w, --where, --location
print physical location of Info file.
The first non-option argument, if present, is the menu entry
to start from; it is searched for in all `dir' files along
INFOPATH. If it is not present, info merges all `dir' files
and shows the result. Any remaining arguments are treated
as the names of menu items relative to the initial node vis-
ited.
For a summary of key bindings, type h within Info.
EXAMPLES
info show top-level dir menu
info info
show the general manual for Info readers
info info-stnd
show the manual specific to this Info program
info emacs
start at emacs node from top-level dir
info emacs buffers
start at buffers node within emacs manual
info --show-options emacs
start at node with emacs' command line options
info --subnodes -o out.txt emacs
dump entire manual to out.txt
info -f ./foo.info
show file ./foo.info, not searching dir
REPORTING BUGS
Email bug reports to bug-texinfo@gnu.org, general questions
and discussion to help-texinfo@gnu.org. Texinfo home page:
http://www.gnu.org/software/texinfo/
COPYRIGHT
Copyright (C) 2008 Free Software Foundation, Inc. License
GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redis-
tribute it. There is NO WARRANTY, to the extent permitted
by law.
info 4.13 Last change: September 2008 2
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | text/texinfo |
|Stability | Volatile |
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from
http://ftp.gnu.org/gnu/texinfo/texinfo-4.13.tar.gz
Further information about this software can be found on the
open source community website at http://www.gnu.org/soft-
ware/texinfo/.
info 4.13 Last change: September 2008 3
