git-shell
(1)
Name
git-shell - only SSH access
Synopsis
git shell [-c <command> <argument>]
Description
Git Manual GIT-SHELL(1)
NAME
git-shell - Restricted login shell for Git-only SSH access
SYNOPSIS
DESCRIPTION
A login shell for SSH accounts to provide restricted Git
access. When -c is given, the program executes <command>
non-interactively; <command> can be one of git receive-pack,
git upload-pack, git upload-archive, cvs server, or a
command in COMMAND_DIR. The shell is started in interactive
mode when no arguments are given; in this case, COMMAND_DIR
must exist, and any of the executables in it can be invoked.
cvs server is a special command which executes
git-cvsserver.
COMMAND_DIR is the path "$HOME/git-shell-commands". The user
must have read and execute permissions to the directory in
order to execute the programs in it. The programs are
executed with a cwd of $HOME, and <argument> is parsed as a
command-line string.
GIT
Part of the git(1) suite
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | developer/versioning/git |
|Stability | Uncommitted |
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from http://git-
core.googlecode.com/files/git-1.7.9.2.tar.gz
Further information about this software can be found on the
open source community website at http://git-scm.com/.
Git 1.7.9.2 Last change: 02/22/2012 1
