git-peek-remote
(1)
Name
git-peek-remote - List the references in a remote repository
Synopsis
git peek-remote [--upload-pack=<git-upload-pack>] [<host>:]<directory>
Description
Git Manual GIT-PEEK-REMOTE(1)
NAME
SYNOPSIS
DESCRIPTION
This command is deprecated; use git ls-remote instead.
OPTIONS
Use this to specify the path to git-upload-pack on the
remote side, if it is not found on your $PATH. Some
installations of sshd ignores the user's environment
setup scripts for login shells (e.g. .bash_profile) and
your privately installed git may not be found on the
system default $PATH. Another workaround suggested is to
set up your $PATH in ".bashrc", but this flag is for
people who do not want to pay the overhead for
non-interactive shells, but prefer having a lean .bashrc
file (they set most of the things up in .bash_profile).
<host>
A remote host that houses the repository. When this part
is specified, git-upload-pack is invoked via ssh.
<directory>
The repository to sync from.
GIT
Part of the git(1) suite
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | developer/versioning/git |
|Stability | Uncommitted |
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from http://git-
core.googlecode.com/files/git-1.7.9.2.tar.gz
Git 1.7.9.2 Last change: 02/22/2012 1
Further information about this software can be found on the
open source community website at http://git-scm.com/.
Git 1.7.9.2 Last change: 02/22/2012 2
