git-merge-index
(1)
Name
git-merge-index - Run a merge for files needing merging
Synopsis
git merge-index [-o] [-q] <merge-program> (-a | [--] <file>*)
Description
Git Manual GIT-MERGE-INDEX(1)
NAME
SYNOPSIS
DESCRIPTION
This looks up the <file>(s) in the index and, if there are
any merge entries, passes the SHA1 hash for those files as
arguments 1, 2, 3 (empty argument if no file), and <file> as
argument 4. File modes for the three files are passed as
arguments 5, 6 and 7.
OPTIONS
Do not interpret any more arguments as options.
-a
Run merge against all files in the index that need
merging.
-o
Instead of stopping at the first failed merge, do all of
them in one shot - continue with merging even when
previous merges returned errors, and only return the
error code after all the merges.
-q
Do not complain about a failed merge program (a merge
program failure usually indicates conflicts during the
merge). This is for porcelains which might want to emit
custom messages.
If git merge-index is called with multiple <file>s (or -a)
then it processes them in turn only stopping if merge
returns a non-zero exit code.
Typically this is run with a script calling git's imitation
of the merge command from the RCS package.
A sample script called git merge-one-file is included in the
distribution.
ALERT ALERT ALERT! The git "merge object order" is different
from the RCS merge program merge object order. In the above
ordering, the original is first. But the argument order to
the 3-way merge program merge is to have the original in the
middle. Don't ask me why.
Examples:
Git 1.7.9.2 Last change: 02/22/2012 1
torvalds@ppc970:~/merge-test> git merge-index cat MM
This is MM from the original tree. # original
This is modified MM in the branch A. # merge1
This is modified MM in the branch B. # merge2
This is modified MM in the branch B. # current contents
or
torvalds@ppc970:~/merge-test> git merge-index cat AA MM
cat: : No such file or directory
This is added AA in the branch A.
This is added AA in the branch B.
fatal: merge program failed
where the latter example shows how git merge-index will stop
trying to merge once anything has returned an error (i.e.,
cat returned an error for the AA file, because it didn't
exist in the original, and thus git merge-index didn't even
try to merge the MM thing).
GIT
Part of the git(1) suite
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | developer/versioning/git |
|Stability | Uncommitted |
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from http://git-
core.googlecode.com/files/git-1.7.9.2.tar.gz
Further information about this software can be found on the
open source community website at http://git-scm.com/.
Git 1.7.9.2 Last change: 02/22/2012 2
