git-remote-fd
(1)
Name
git-remote-fd - Reflect smart transport stream back to
caller
Synopsis
"fd::<infd>[,<outfd>][/<anything>]" (as URL)
Description
Git Manual GIT-REMOTE-FD(1)
NAME
caller
SYNOPSIS
DESCRIPTION
This helper uses specified file descriptors to connect to a
remote git server. This is not meant for end users but for
programs and scripts calling git fetch, push or archive.
If only <infd> is given, it is assumed to be a bidirectional
socket connected to remote git server (git-upload-pack,
git-receive-pack or git-upload-achive). If both <infd> and
<outfd> are given, they are assumed to be pipes connected to
a remote git server (<infd> being the inbound pipe and
<outfd> being the outbound pipe.
It is assumed that any handshaking procedures have already
been completed (such as sending service request for git://)
before this helper is started.
<anything> can be any string. It is ignored. It is meant for
providing information to user in the URL in case that URL is
displayed in some context.
ENVIRONMENT VARIABLES
GIT_TRANSLOOP_DEBUG
If set, prints debugging information about various
reads/writes.
EXAMPLES
git fetch fd::17 master
Fetch master, using file descriptor #17 to communicate
with git-upload-pack.
git fetch fd::17/foo master
Same as above.
git push fd::7,8 master (as URL)
Push master, using file descriptor #7 to read data from
git-receive-pack and file descriptor #8 to write data to
same service.
git push fd::7,8/bar master
Same as above.
DOCUMENTATION
Documentation by Ilari Liusvaara and the git list
<git@vger.kernel.org[1]>
Git 1.7.9.2 Last change: 02/22/2012 1
GIT
Part of the git(1) suite
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | developer/versioning/git |
|Stability | Uncommitted |
NOTES
1. git@vger.kernel.org
mailto:git@vger.kernel.org
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from http://git-
core.googlecode.com/files/git-1.7.9.2.tar.gz
Further information about this software can be found on the
open source community website at http://git-scm.com/.
Git 1.7.9.2 Last change: 02/22/2012 2
