git-remote-ext
(1)
Name
git-remote-ext - Bridge smart transport to external command.
Synopsis
git remote add <nick> "ext::<command>[ <arguments>...]"
Description
Git Manual GIT-REMOTE-EXT(1)
NAME
SYNOPSIS
DESCRIPTION
This remote helper uses the specified <command> to connect
to a remote git server.
Data written to stdin of the specified <command> is assumed
to be sent to a git:// server, git-upload-pack,
git-receive-pack or git-upload-archive (depending on
situation), and data read from stdout of <command> is
assumed to be received from the same service.
Command and arguments are separated by an unescaped space.
The following sequences have a special meaning:
Literal space in command or argument.
Literal percent sign.
%s
Replaced with name (receive-pack, upload-pack, or
upload-archive) of the service git wants to invoke.
%S
Replaced with long name (git-receive-pack,
git-upload-pack, or git-upload-archive) of the service
%G (must be the first characters in an argument)
This argument will not be passed to <command>. Instead,
it will cause the helper to start by sending git://
service requests to the remote side with the service
field set to an appropriate value and the repository
field set to rest of the argument. Default is not to
send such a request.
This is useful if remote side is git:// server accessed
over some tunnel.
%V (must be first characters in argument)
it sets the vhost field in the git:// service request
(to rest of the argument). Default is not to send vhost
in such request (if sent).
Git 1.7.9.2 Last change: 02/22/2012 1
ENVIRONMENT VARIABLES:
GIT_TRANSLOOP_DEBUG
If set, prints debugging information about various
reads/writes.
ENVIRONMENT VARIABLES PASSED TO COMMAND:
GIT_EXT_SERVICE
Set to long name (git-upload-pack, etc...) of service
helper needs to invoke.
GIT_EXT_SERVICE_NOPREFIX
Set to long name (upload-pack, etc...) of service helper
needs to invoke.
EXAMPLES:
This remote helper is transparently used by git when you use
commands such as "git fetch <URL>", "git clone <URL>", ,
"git push <URL>" or "git remote add <nick> <URL>", where
<URL> begins with ext::. Examples:
"ext::ssh -i /home/foo/.ssh/somekey user@host.example %S
foo/repo"
Like host.example:foo/repo, but use
/home/foo/.ssh/somekey as keypair and user as user on
remote side. This avoids needing to edit .ssh/config.
"ext::socat -t3600 - ABSTRACT-CONNECT:/git-server
%G/somerepo"
Represents repository with path /somerepo accessable
over git protocol at abstract namespace address
/git-server.
"ext::git-server-alias foo %G/repo"
Represents a repository with path /repo accessed using
the helper program "git-server-alias foo". The path to
the repository and type of request are not passed on the
command line but as part of the protocol stream, as
usual with git:// protocol.
"ext::git-server-alias foo %G/repo %Vfoo"
the helper program "git-server-alias foo". The hostname
for the remote server passed in the protocol stream will
be "foo" (this allows multiple virtual git servers to
share a link-level address).
"ext::git-server-alias foo %G/repo% with% spaces %Vfoo"
Represents a repository with path /repo with spaces
accessed using the helper program "git-server-alias
foo". The hostname for the remote server passed in the
protocol stream will be "foo" (this allows multiple
virtual git servers to share a link-level address).
Git 1.7.9.2 Last change: 02/22/2012 2
"ext::git-ssl foo.example /bar"
Represents a repository accessed using the helper
program "git-ssl foo.example /bar". The type of request
can be determined by the helper using environment
variables (see above).
DOCUMENTATION
Documentation by Ilari Liusvaara, Jonathan Nieder and the
git list <git@vger.kernel.org[1]>
GIT
Part of the git(1) suite
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | developer/versioning/git |
|Stability | Uncommitted |
NOTES
1. git@vger.kernel.org
mailto:git@vger.kernel.org
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from http://git-
core.googlecode.com/files/git-1.7.9.2.tar.gz
Further information about this software can be found on the
open source community website at http://git-scm.com/.
Git 1.7.9.2 Last change: 02/22/2012 3
