head
(1g)
Name
head - output the first part of files
Synopsis
head [OPTION]... [FILE]...
Description
User Commands HEAD(1)
NAME
SYNOPSIS
DESCRIPTION
Print the first 10 lines of each FILE to standard output.
With more than one FILE, precede each with a header giving
the file name. With no FILE, or when FILE is -, read stan-
dard input.
Mandatory arguments to long options are mandatory for short
options too.
-c, --bytes=[-]K
print the first K bytes of each file; with the leading
'-', print all but the last K bytes of each file
-n, --lines=[-]K
print the first K lines instead of the first 10; with
the leading '-', print all but the last K lines of each
file
-q, --quiet, --silent
never print headers giving file names
-v, --verbose
always print headers giving file names
--help
display this help and exit
--version
output version information and exit
K may have a multiplier suffix: b 512, kB 1000, K 1024, MB
1000*1000, M 1024*1024, GB 1000*1000*1000, G 1024*1024*1024,
and so on for T, P, E, Z, Y.
AUTHOR
Written by David MacKenzie and Jim Meyering.
REPORTING BUGS
Report head bugs to bug-coreutils@gnu.org
GNU coreutils home page: <http://www.gnu.org/software/core-
utils/>
General help using GNU software: <http://www.gnu.org/geth-
elp/>
Report head translation bugs to <http://translationpro-
ject.org/team/>
GNU coreutils 8.16 Last change: March 2012 1
COPYRIGHT
Copyright (C) 2012 Free Software Foundation, Inc. License
GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redis-
tribute it. There is NO WARRANTY, to the extent permitted
by law.
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | file/gnu-coreutils |
|Stability | Uncommitted |
SEE ALSO
The full documentation for head is maintained as a Texinfo
manual. If the info and head programs are properly
installed at your site, the command
info coreutils 'head invocation'
should give you access to the complete manual.
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from
http://ftp.gnu.org/gnu/coreutils/coreutils-8.16.tar.xz
Further information about this software can be found on the
open source community website at http://www.gnu.org/soft-
ware/coreutils/.
GNU coreutils 8.16 Last change: March 2012 2
