swift-container-auditor
(1)
Name
swift-container-auditor - OpenStack Swift container auditor
Synopsis
/usr/lib/swift/swift-container-auditor [CONFIG] [-h|--help]
[-v|--verbose] [-o|--once]
Description
OpenStack Swift swift-container-auditor(1)
NAME
SYNOPSIS
DESCRIPTION
The container auditor crawls the local container system
checking the integrity of container objects. If corruption
is found (in the case of bit rot, for example), the file is
quarantined, and replication will replace the bad file from
another replica.
The options are as follows:
-v
--verbose
log to console
-o
--once
only run one pass of daemon
The container auditor should be enabled and disabled using
the Solaris Service Management Facility, smf(5). The ser-
vice FMRI for the container auditor is:
svc:/application/openstack/swift/swift-container-auditor
DOCUMENTATION
More in depth documentation in regards to swift-container-
auditor and also about OpenStack Swift as a whole can be
found at http://swift.openstack.org/index.html
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | cloud/openstack/swift |
|Stability | Uncommitted |
OpenStack Last change: 8/26/2011 1
SEE ALSO
container-server.conf(4), smf(5)
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from http://launch-
pad.net/swift/havana/1.10.0/+download/swift-1.10.0.tar.gz
Further information about this software can be found on the
open source community website at http://www.openstack.org/.
OpenStack Last change: 8/26/2011 2
