Modify Network Settings From the Oracle ILOM Web Interface
If you want to modify the network settings currently configured for the server from the Oracle
ILOM web interface, use the following procedure.
Log in to the Oracle ILOM web interface using the relevant steps in
Log In to Oracle ILOM Using a Remote Ethernet
Connection.
Select ILOM Administration > Connectivity from the navigation tree on the left.
The Network Settings page appears. The settings configured on your device are
displayed.
Perform the network configuration instructions that apply to your network environment:
Test the IPv4 or IPv6 network configuration from Oracle ILOM using the Network Test Tools
(Ping and Ping 6).
For details, see
Test IPv4 or IPv6
Network Configuration From the Oracle ILOM Web Interface.
