Remove a Storage Drive Filler Panel (CRU)
For information about component filler panels, see
Component Filler Panels.
Prepare the server for service. See
Preparing to Service
the Server.
If necessary, press the Locate indicator button to deactivate the indicator.
Identify the storage drive filler panel you want to remove.
Push the release button to open the latch.
To remove the filler panel, use the latch to pull the filler panel out of the slot.
