Caution - If a power supply fails and you do not have a replacement available, ensure proper airflow by leaving the failed power supply installed in the server until you replace it with a new power supply. |
This procedure describes how to remove a power supply from the server.
Before You Begin
For serviceability considerations, see Component Serviceability.
For power supply designation information, see Component Designations.
The server can be configured to use low‑line 110VAC input voltage in a 2-processor configuration, however 4-processor configurations require power supplies to be configured with high‑line 220VAC input.
To perform a cold-service procedure, see Prepare the Server for Cold Service.
A lit amber color Service Action Required indicator indicates a failed component. For more information, see Power Supply Reference.
