Processor (CPU)
Intel Xeon® E7-8895 v2 15-core 2.8 GHz processor.
Supported configurations:
Memory
Up to eight memory riser cards are supported (two risers per CPU)
in the server chassis. Each memory riser supports up to twelve
DDR3-1600 ECC low-voltage registered or load-reduced DIMMs, allowing
up to twenty-four DIMMs per processor. Installed DIMMs must be the
same type and size.
In a two CPU system,
you can install up to a maximum of 1.5 TB of system
memory.
In a four CPU system,
you can install up to a maximum of 3 TB of system
memory.
Refer to the Service Manual for DIMM
population rules and supported configurations.
Storage devices
For internal storage, the server chassis provides:
Six 2.5-inch drive bays, accessible through the front
panel. All bays can be populated with SAS-2 HDDs or SATA-3
SSDs.
An optional DVD+/-RW drive on the front of the server,
below the drive bays. This SATA DVD drive connects to a
USB-SATA bridge, so that the drive appears to the system as
a USB storage device.
SAS-2 HBA PCIe card options:
Sun Storage 6 Gb SAS PCIe
HBA. Supports RAID levels : 0, 1,
10.
RAID HBA. Supports RAID levels : 0, 1,
1E, 10, 5, 5EE, 6 with Battery Backed Write Cache
(BBWC).
USB 2.0 ports
Two ports on the front of the system and two on the
back.
Two internal ports on the motherboard. One port holds the
optional factory-installed Oracle System Assistant (OSA)
stick–a bootable device used to configure the server.
A second port can hold a USB flash device for system
booting.
VGA ports
Two high-density DB-15 video ports are available. One on the front
of the system and one on the back. The server includes an embedded
VGA 2D graphics controller with 8 MB, which supports resolutions up
to 1600 x 1200 x 16bits @ 60 Hz (1024 x 768 when viewed remotely
using Oracle ILOM Remote Console Plus RKVMS).
Note -
The VGA port available on the back panel supports VESA Device
Data Channel for monitor identification.
PCI Express 3.0 I/O slots
Eleven PCI Express 3.0 slots that accommodate low-profile PCIe
cards. In configurations that include a SAS HBA card, the HBA card
is installed in slot 2. All slots support x8 PCIe connections. Two
slots are also capable of supporting x16 PCIe cards.
Slots 1 through 7, 9, and 10: x8 connector
Slots 8 and 11: x8 or x16 connector
Note -
PCIe slots 7 through 11 are only functional in four CPU
systems.
PCI Express I/O cards
Ethernet ports
Four 10 GbE RJ-45 Ethernet ports on back panel.
Service processor
Emulex Pilot 3 baseboard management controller (BMC)
mounted on a daughterboard.
Supports industry-standard IPMI feature set.
Supports remote KVMS, USB, DVD, CD, floppy, and ISO image over
IP.
Includes a serial port.
Supports Ethernet access to SP through a dedicated RJ-45 Gigabit
Ethernet (10/100/1000) management port and optionally through one of
the host 10 GbE ports (sideband management).
Power supplies
Two 1030/2060 Watt AC input auto-ranging hot-swappable power
supplies.
Note -
A two-CPU system can operate with low-line 100 - 127 VAC or
high-line 200 - 240 VAC sources. A four-CPU system can only
operate with high-line 200 - 240 VAC sources.
Cooling fans
Six hot-swappable, redundant fans at chassis front (top-loading);
redundant fans in each power supply.
Management software
The following options are available:
Oracle Integrated Lights Out Manager (ILOM) on the service
processor.
Oracle System Assistant (OSA) on an optional internal USB
flash drive.
Oracle Hardware Management Pack on the optional OSA
internal USB flash drive.
Oracle Enterprise Management Ops Center, downloadable from
the Oracle site.
