When servicing the components in this section, unplug the AC power cords and use ESD protection.
Cover plates are plastic inserts that attach to the CPU load plate and protect the pins of an unoccupied CPU socket. Cover plates are used in a two-CPU server (for the unoccupied sockets) and on replacement motherboards. When replacing a motherboard, remove the covers and installed them on the failed board.
Before You Begin
For serviceability considerations, see Component Serviceability.
For fan module designation information, see Component Designations.
The levers are numbered with their required order of operation. The left-side lever (when viewed from the front of the server) must be operated first.
When the second lever is in its fully-open position, the load plate is unlocked.
A black plastic cover (CPU cover plate) is attached to the load plate.
The cover is snap-fitted into the opening in the load plate.
Next Steps
