Log In to Oracle ILOM Using a Local Serial Connection
This procedure does not require that you know the IP address of the server SP. It does require
that you have an Oracle ILOM Administrator account.
Note -
The default Oracle ILOM Administrator account shipped with the server is
root and its password is changeme. If this default
Administrator account has since been changed, contact your system administrator for an Oracle ILOM
user account with Administrator privileges.
Before You Begin
You must have already connected a serial cable from a terminal (or terminal emulation client)
to the SER MGT port on the back of the server. For more information on this connection, see
Cable the Server.
At the terminal (or terminal emulation client), ensure that the following serial communication
settings are configured:
8N1: eight data bits, no parity, one stop bit
9600 baud
Disable hardware flow control (CTS/RTS)
At the terminal keyboard, press Enter to establish the serial console connection to Oracle
ILOM.
A login prompt to Oracle ILOM appears.
Log in to the Oracle ILOM command-line interface (CLI) using an Administrator account.
Oracle ILOM displays a default command prompt (->), indicating that you have successfully
logged in to Oracle ILOM.
