Go to main content
Sun Server X4-4 HTML Documentation Collection
Exit Print View
Updated: October 2015
Download Firmware and Software Using My Oracle Support
  1. Go to the following web site: https://support.oracle.com
  2. Sign in to My Oracle Support.
  3. At the top of the page, click the Patches and Updates tab.
    The Patches and Updates screen appears.
  4. In the Search screen, click Product or Family (Advanced).
    The screen appears with search fields.
  5. In the Product field, select the product from the drop-down list.
    Alternatively, type a full or partial product name (for example, Sun Server X4-4) until a match appears.
  6. In the Release field, select a software release from the drop-down list.
  7. Click Search.
    The patches available for downloading are listed.
    See Available Software Release Packages for a description of the available downloads.
  8. To select a patch for downloading, click on it (you can use the shift key to select more than one patch).
    A pop-up action panel appears. The pop-up panel contains several action options, including the Add to Plan and Download options. For information about the Add to Plan option, click on the associated drop-down button and select “Why use a plan?”
  9. To download the patch(es), click Download in the pop-up action panel.
    The File Download dialog box appears.
  10. In the File Download dialog box, click on the patch zip file.
    The patch file downloads.
