Go to main content
Sun Server X4-4 HTML Documentation Collection
Exit Print View
Updated: October 2015
Oracle ILOM Network Defaults
The Sun Server X4-4 supports dual-stack IPv4 and IPv6 settings, which enable Oracle ILOM to fully operate in an IPv4 and IPv6 network environment.
  • For IPv4 configurations, DHCP is enabled by default, allowing a DHCP server on the network to automatically assign network settings to the server.
  • For IPv6 configurations, IPv6 stateless auto-configuration is enabled by default, allowing an IPv6 router on the network to assign the network settings.
In a typical configuration, you will accept these default settings.
Note -  To determine an automatically assigned IP address or host name for your server, use the network tools provided with the DHCP server or IPv6 router.
