Go to main content
Sun Server X4-4 HTML Documentation Collection
Exit Print View
Updated: October 2015
Processor Subsystem
The Sun Server X4-4 uses the Intel Xeon E7-8895 v2 15-core 2.8 GHz processor and supports two CPU-based configurations: a two-CPU configuration and a four-CPU configuration.
Two-CPU Configuration
Servers with two CPUs have CPUs and heatsinks in sockets 0 and 1 and CPU cover plates installed in sockets 2 and 3. This configuration requires four memory riser cards and an air baffle to control airflow for maximum cooling. The following illustration shows the components that distinguish a two-CPU server configuration.
image:An illustration showing the inside of a server with a minimum CPU configuration
Call Out
Description
1
Air baffle
2
CPU P1
3
CPU P0
4
Memory riser card P1/MR1
5
Memory riser card P1/MR0
6
Memory riser card P0/MR1
7
Memory riser card P0/MR0
For more information, see Two-CPU Block Diagram.
Four-CPU Configuration
In addition to four CPUs, this configuration requires eight memory riser cards. The following illustration shows the components in a server configured with four-CPUs.
image:An illustration showing the server internals for a four-CPU server.
Call Out
Description
Call Out
Description
1
Memory riser card P3/MR1
7
2
Memory riser card P3/MR0
8
3
Memory riser card P2/MR1
9
CPU P3
4
Memory riser card P2/MR0
10
CPU P2
5
11
CPU P1
6
12
CPU P0
The four-CPU configuration offers a greater level of resiliency with redundant QPI interconnects that allow working CPUs to route around a disabled CPU as the system starts.
For more information, see Four-CPU Block Diagram.
