Use this procedure to connect power cords to the server. When the power cords are connected, the server will be in standby power mode. The following figure shows the location of the AC power connectors.
When power is connected, the server boots into standby power mode:
The SP OK indicator [2] flashes while the SP is starting, and the system OK indicator [1] remains off until the SP is ready.
After a few minutes, the system OK indicator slowly flashes the standby blink pattern (0.1 seconds on, 2.9 seconds off), indicating that the SP (and Oracle ILOM) is ready for use. Note that the server is not initialized or fully powered on at this point.
Next Steps
