Go to main content
Sun Server X4-4 HTML Documentation Collection
Exit Print View
Updated: October 2015
Storage Drive Reference
This section shows the location and explains the functions of the storage drive status indicators.
image:An illustration showing the storage drive front panel.
Figure Legend
Description
1
OK to Remove indicator
2
Service Action Required indicator
3
OK/Activity indicator
The functions of the drive status indicators are described below.
For indicator blink rate information, see Indicator Blink Rates.
OK to Remove Indicator
image:Ok to remove icon
Blue indicator. Indicates that the storage drive can be removed safely during a hot-service operation.
Service Action Required Indicator
image:Service action icon
Amber indicator. Indicates that the storage drive is faulty. The front and back panel Service Action Required indicators are also lit if the system detects a storage drive fault.
OK/Activity Indicator
image:An illustration showing the OK icon.
Green indicator. Indicates that the drive is properly inserted into the system. Indicator flashes when the drive is being accessed.
See Also:
