Disconnect the server from the AC power and protect components from ESD by wearing an antistatic wrist strap.
Depending on whether you are adding a new CPU and heatsink, or replacing one or both of these components because they are damaged, your kit might contain the following:
CPU and a heatsink with thermal compound applied
Heatsink with thermal compound applied
CPU with a syringe of thermal compound
Before You Begin
For serviceability considerations, see Component Serviceability.
For fan module designation information, see Component Designations.
The tool is used to remove and install the CPU in the socket. The top side of the replacement tool has a button in the center and a tab on one side. Pressing down on the button opens the tool. Pressing the tab releases the button and closes the tool.
This action opens the tool.
On one corner of the tool there is a label with a downward pointing triangle. Likewise, the CPU is marked with a triangle on one of its corners. This is a key that aids in correctly positioning the tool and the CPU with the CPU socket. The tool and the CPU are correctly positioned with the socket when all of the triangles are aligned.
The CPU is not yet secured in the tool.
This action is accompanied by a click sound as the tool closes and grabs the CPU. The CPU should now be secured in the tool.
When the CPU is secured in the tool, there is no side-to-side movement of the CPU within the tool.
This positions the tool with the topside facing upward.
When the CPU is correctly positioned, there is no side-to-side movement of the CPU within the socket.
This action is accompanied by a click sound as the tool opens and releases the CPU.
The right side lever must be closed first.
Do not spread the thermal compound. The pressure applied during the heatsink installation performs this action.
Once the heatsink is in contact with the CPU, avoid extra movement of the heatsink.
For instructions on clearing server faults, refer to the Oracle Integrated Lights Out Manager (ILOM) 3.2.2 Users Guide.
Next Steps
Back to Replace a Faulty CPU (FRU)
-or-
Back to Replace the Motherboard (FRU)
