Available Software Release Packages
Downloads on My Oracle Support are grouped by product family, then product, then version. The
version contains one or more downloads (patches).
For servers and blades, the pattern is similar. The product is the server. Each server
contains a set of releases. These releases are not true software product releases, but rather are
releases of updates for the server. These updates are called software releases and comprise several
downloads, all tested together. Each download contains firmware, drivers, or utilities.
My Oracle Support has the same set of download types for this server family as shown in the following table. The same firmware and software can also be downloaded using Oracle System Assistant.
Sun Server X4-4 SW version – Firmware Pack
All the system firmware, including Oracle ILOM, BIOS, and option card firmware.
You need the latest firmware.
Sun Server X4-4 SW version – OS Pack
An OS Pack is available for each supported operating system version. Each OS Pack includes a
package of all tools, drivers, and utilities for that version of the OS.
Software includes Oracle Hardware Management Pack and LSI MegaRAID software.
For the Windows OS, this OS Pack also includes Intel Network Teaming and Install Pack.
You need to update OS-specific drivers, tools, or utilities.
Sun Server X4-4 SW version – All Packs
Includes the Firmware Pack, all OS Packs, and all documents.
This pack does not include Oracle VTS or the Oracle System Assistant image.
You need to update a combination of system firmware and OS-specific software.
Sun Server X4-4 SW version – Diagnostics
Oracle VTS diagnostics image.
You need the Oracle VTS diagnostics image.
Sun Server X4-4 SW version – Oracle System Assistant
Oracle System Assistant recovery and
ISO update image.
You need to manually recover or update
Each of the downloads is a zip file that contains a ReadMe file and a set of subdirectories
containing firmware or software files. The ReadMe file contains details on the components that have
changed since the prior software release and the bugs that have been fixed.
