Go to main content
Sun Server X4-4 HTML Documentation Collection
Exit Print View
Updated: October 2015
Test IPv4 or IPv6 Network Configuration From the Oracle ILOM CLI
  1. Use the cd command to navigate to the /SP/network/test directory:
    -> cd /SP/network/test
  2. At the CLI prompt, type the show command to view the network test targets and properties.
    For example, the following output shows the test target properties.
    -> show
    /SP/network/test
    Targets:
    Properties:
     ping = (Cannot show property)
     ping6 = (Cannot show property)
    Commands:
     cd
     set
     show
  3. Use the set ping or set ping6 command to send a network test from the device to a network destination. For example:
    -> set ping=device_ipv4_address_on network
    -> set ping6=device_ipv6_address_on network
    Property
    Value to Set
    Description
    ping
    <IPv4_address>
    Type the set ping= command at the command prompt followed by the IPv4 test destination address. For example: set ping=10.8.183.106
    Ping of 10.8.183.106 succeeded
    ping6
    <IPv6_address>
    Type the set ping6= command followed by the IPv6 test destination address. For example: set ping6=fe80::211:5dff:febe:5000
    Ping of fe80::211:5dff:febe:5000 succeeded
