Oracle ILOM
SP firmware
Monitors environmental conditions and component functionality sensors, generates alerts,
performs fault isolation, and provides remote access.
Can function on either standby power mode or full power mode and is not OS dependent.
Designed for remote and local access.
Preboot Menu
SP firmware
Enables you to restore some Oracle ILOM default settings when Oracle ILOM is not accessible.
Can function on standby power and when operating system is not running.
Local, but remote serial access is possible if the SP serial port is connected to a
network-accessible terminal server.
Hardware-based LED indicators
Hardware and SP firmware
Indicates status of overall system and particular components.
Available when system power is available.
Local, but sensor and indicators are accessible from Oracle ILOM web interface or command-line
interface (CLI).
Power-on Self-Test (POST)
Host firmware
Tests core components of system: CPUs, memory, and motherboard I/O bridge integrated
circuits.
Runs on startup. Available when the operating system is not running.
Local, but can be accessed through Oracle ILOM Remote Console.
U-Boot
SP firmware
Initializes and tests aspects of the service processor (SP) prior to booting Oracle ILOM and
the operating system. Tests SP memory, SP, network devices and I/O devices.
UEFI Diagnostics
System BIOS
The UEFI diagnostics can test and detect problems on all CPU, memory, disk drives, and network
ports. It is used on systems that support UEFI.
You can use either the Oracle ILOM web interface or the command-line interface (CLI) to run
UEFI diagnostics..
Remote access through Oracle ILOM Remote Console.
Oracle Solaris commands
Operating system software
Displays various kinds of system information.
Requires operating system.
Local, and over network.
Oracle Linux commands
Oracle VTS
Diagnostic tool standalone software
Exercises and stresses the system, running tests in parallel.
Requires operating system. Install Oracle VTS software separately.
View and control over network.
