This procedure describes how to install a fan module in the server.
Fan modules are hot-serviceable components. It is not necessary to power off the server or to remove the server cover to service a fan module. However, depending on server rack configuration, it might be necessary to partially extend the server from the rack to access the fan modules. Take care when partially extending the server from the rack during hot service. Ensure that the cables at the back of the server are not dislodged, particularly the power cables. You can also perform this procedure using cold service. Optional steps for partially extending the server from the rack are included in this procedure.
Before You Begin
For serviceability considerations, see Component Serviceability.
For fan module designation information, see Component Designations.
For instructions on removing a fan module, see Remove a Fan Module.
This is necessary to ensure the indicator status is cleared before you insert the new fan. See Fan Module Reference for fan module indicator locations.
The fan modules are keyed to ensure that they are installed in the correct orientation.
See Server Front Panel Features and Server Back Panel Features for locations of system indicators.
